what to do with my rear end #1194917
03/11/12 03:00 AM
03/11/12 03:00 AM
waco tx
gogo318 Offline OP
gogo318  Offline OP
waco tx
ok so... took the van for some time trials my best was a 15.1 with a blown power valve (or two)currently in it is a 318 that i built copying an engine masters build there motor made 415 hp and like 400 ft lbs so we will assume mine dose too the trans is a 727 tci strretfighter with a 1800 stall and a full race transgo shift kit in the rear is bone stock except new fluid im hearing its like 3.55 gears every one sayes the rear is killing me but before i toss a grand at some new gears and a limited slip im considering swapping in this mild rv 440/727 i have on the shop floor would the bigger motor make better use of the larger gears or should i still go smaller if so what would you recommend
67 charger fastback 318 stock 67 belvedere II 4dr soft top built 318 68 newport 2dr hard top 318 84 b150 440/727 84 d150 short wheel step side 4x4 lifted 87 omnitruck (you just have to see it ) new addition 63 dart wagon !!!
Re: what to do with my rear end [Re: gogo318] #1194918
03/11/12 03:09 AM
03/11/12 03:09 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
"What to do with my rear end?"
That can be taken in so many ways. Whatever you decide to do with it, I don't want to know.
Re: what to do with my rear end [Re: gogo318] #1194919
03/11/12 03:12 AM
03/11/12 03:12 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I took the van for some time trials. My best was a 15.1 with a blown power valve. (or two) Currently it is a 318 that I built copying an engine masters build. Their motor made 415 hp and something like 400 ft lbs so we will assume mine does too. The trans is a 727 TCI Streetfighter with a 1800 stall and a full race TransGo shift kit. The rear is bone stock except new fluid. 3.55 gears. Everyone says the rear is killing me but before I toss a grand at some new gears and a limited slip, I'm considering swapping in this mild rv 440 and 727. Would the bigger motor make better use of the larger gears or should I still go smaller? What would you recommend?
If you have the parts for a 440 swap, and this isn't a daily driver, go big! A heavy vehicle needs torque to move!
Oh, are you sure on the 1800 stall? that seems really low. A STOCK 318 truck converter stalls in that range.
Re: what to do with my rear end [Re: Kern Dog] #1194920
03/11/12 03:17 AM
03/11/12 03:17 AM
waco tx
gogo318 Offline OP
gogo318  Offline OP
waco tx
nope shes a toy and if/when i put a 440 in it it wont be mild and shes not all that heavy last time i weighed it i think it came in at 3100 just if i put gears in it now will i regret it later when i have the 440 in it?
Re: what to do with my rear end [Re: gogo318] #1194921
03/11/12 01:45 PM
03/11/12 01:45 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
If you think you have 400 hp I'd go looking for the 200 + hp you are not using yet???
at 3100 I'd think a 400 hp gross hp motor would give 13.0's even with 3.55 gears.
so cam, heads, intake, headers, carb and what were your 60 foot and 330's well all the numbers an mph all the way down.
