How much is 705 lbs worth in ET/speed #1194890
03/11/12 01:40 AM
03/11/12 01:40 AM
Michigan, USA
ramman5600 Offline OP
Michigan, USA
Just curious if there is a calculator out there that would estimate weight savings benefits. I'm doing a 6.1 swap into and 3660 lb B-body and was curious to compare to a new srt8 charger as an example that weight 4365. Thanks
-C
Re: How much is 705 lbs worth in ET/speed [Re: ramman5600] #1194891
03/11/12 01:45 AM
03/11/12 01:45 AM
Cab_Burge Online work
Cab_Burge  Online Work
-C
DUDE,your trying to compare Apples to Watermelons, go the other way. Compare the HP from (old weight) and to (new weight)with the same HP and torque
Re: How much is 705 lbs worth in ET/speed [Re: ramman5600] #1194892
03/11/12 04:35 AM
03/11/12 04:35 AM
Utah
topbrent Offline
topbrent  Offline
Utah
http://www.wallaceracing.com/et-hp-mph.php
http://www.wallaceracing.com/Calculators.htm
Your ET / MPH computed from your vehicle weight of 4365 pounds and HP of 425 is 12.66 seconds and MPH of 105.82 MPH.
Your ET / MPH computed from your vehicle weight of 3660 pounds and HP of 425 is 11.94 seconds and MPH of 112.22 MPH.
Re: How much is 705 lbs worth in ET/speed [Re: topbrent] #1194893
03/11/12 05:05 PM
03/11/12 05:05 PM
Michigan, USA
Michigan, USA
Thanks. Exactly was I was looking for. approx. .1 sec per 100 lbs
