Edlebrock Carbs, Any good?
#1194686
03/10/12 10:13 PM
03/10/12 10:13 PM
Posts: 2,648 GA
Boosted
GA
Was wondering what your take on these where. I need two for my long ram and can get a real good deal on two used ones...
I have no problem rebuilding them but was wondering how well they worked...Adjustment and and tuning... This is going on an almost stock motor..
Opinions please.............
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
Re: Edlebrock Carbs, Any good?
[Re: Boosted]
#1194687
03/10/12 10:16 PM
03/10/12 10:16 PM
Posts: 96,666 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
Yes they are. I've never had any trouble with any of the Carter or Eddy carbs. The Eddy carb on the Ramcharger is about 20 years old. The one on my van is about 10 years old. The ones on my brother's '71 Sebring are about 2 years old - no trouble with them.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: ScottSmith_Harms]
#1194690
03/10/12 11:51 PM
03/10/12 11:51 PM
Posts: 2,648 GA
Boosted
GA
This car did not come with the long ram so I am making up stuff to use... Small cam in a 383 with 10=1 comp and headers...
The two he has are the 600cfm ones...
2011 RAM3500
#1194694
03/11/12 02:06 PM
03/11/12 02:06 PM
Challenger 1
Cincinnati, Ohio
Well, a 383 is not going to like all that fuel so you'll likely want to jet them down a mile, a better combo would be a pair of 500cfm Edelbrocks (1803's). They are factory calibrated for small engines and mild dual quad applications. You will have all of the same linkage, air cleaner, and fuel line issues to deal with but it seems that in your case (custom) that's less problematic.
^^^Good advise^^^^
I have to say I like Eddie carbs. And I do have to say the electric choke models are more for stock motors are are lean from the factory.
I have had a 1405 with fuel in it since 1984 on a 340 and am still using the same carb today.
Lastly I have to recomend leaded race gas if your gonna store your car for long periods like I did. This 1405 sat in my garage on my 340 in my car from 1986-2003 always with 110 leaded race gas. I started it on the average or every 8-9 months during those 17 years and it always started. I tune mine all the time because I take my car nowadays all over the country to drive it. Were at 800' in Cincinnati and Reno NV(have family nearby)and places out west are 6000'+, can't leave it like it is like when were in Cincinnati. And you all mostly know that I've driven it to top of Pikes Peaks at 14000+' twice so far, it's got to be close(jetting) to make it up that monster mountain. Yup it's been a good carb to me. ![](http://i21.photobucket.com/albums/b260/challenger19711/June%2023-11%20and%20after/MVC-002S-2.jpg) One wrong move.... ![](/ubbthreads/images/graemlins/nervous.gif)
[Re: JohnRR]
#1194696
03/12/12 06:45 PM
03/12/12 06:45 PM
Posts: 9,875 MI, usa
dvw
MI, usa
whatever you do AVOID a 750 Ebrock performer , they just plain suck .
Why?
[Re: dvw]
#1194701
03/12/12 06:58 PM
03/12/12 06:58 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
Thanks, I was looking for a good technical answer. Glad you could help. Doug
The calibration on them is hit or miss, mostly miss .
This isn't the first time this has been stated about this carb, for everyone person that has no problems, 3 do, if you want to go and buy one and use it KNOCK YOURSELF OUT.
The Thunder Series is a better carb, it has an adjustable secondary air door, the performer is not adjustable unless you disassemble the carb and either add weight or remove weight from the butterfly plate.
If you go to the tech archives and look for the thread by fast68plymouth on his 383 build you will see that he compared several intakes and carbs on the dyno and the ebrock version of the 750 just flat out did not work well. He tuned it some, yes he knows how to tune a carb, and it just didn't work well at all. He stuck on a Carter 750 AFB , pretty much the same carb , and it was fine, there is just something not right with the calibration that ebroock has these carbs built with.
Considering there are other choices one would be better served using something else.
was that good enough ?
[Re: Boosted]
#1194704
03/12/12 11:24 PM
03/12/12 11:24 PM
Posts: 16,480 Canada
CrAzYMoPaRGuY
Canada
I love Edelbrock carbs. IN PAIRS.
Mild engines, two 500s. A little raunchy... two 600s.
Total drivability and good top end power....
CrAzYMoPaRGuY
[Re: CUDA8U]
#1194705
03/13/12 01:30 AM
03/13/12 01:30 AM
JohnRR
I have been in contact with 2 performance shops that build race and street strip motors and both have said the same thing when i gave all my engine/drivetrain specs.....get rid of the 600 cfm eddy and put an 850 QUICK FUEL ,they both explained these carbs are superior in the tuning department and it's all they run on HP dodge motors.
MUSCLE MOTORS/MICHIGAN
PRO-STOCK EDMONTON
For my application (440hp) I was told the 600 eddy is robbing me of 50hp or more.
Coming from these guys I would have to say they know their carbs.
hope this helps
Not questioning the skill of the names you dropped but it doesn't take a rocket scientist to figure out that a 600 cfm carb is too small for that application ... or maybe it does ??
