Re: Rich Idle Holley 4150
[Re: cjskotni]
#1194582
03/10/12 08:15 PM
03/10/12 08:15 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
A safe torque for Pv's is 100 in/lbs. Did you get them both tight enough?
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: YO7_A66]
#1194584
03/10/12 08:32 PM
03/10/12 08:32 PM
Posts: 1,526 North Carolina
cjskotni
North Carolina
I torqued them to that. Seemed to be about as tight (and same orientation) as the old PV's. One funny thing, I noticed the old PV's had two raskets stacked on top of each other where the Renew kit only provided one gasket for each PV and it was a little thicker....
Whats the timing set at?
around 16 degrees advanced base timing - motor is a 499 stroker - OEM electronic ignition with "chrome ECU"
[Re: Cab_Burge]
#1194587
03/10/12 11:13 PM
03/10/12 11:13 PM
cjskotni
North Carolina
Start over from scratch,set both idle mixture screws to 1.5 turns out from lightly bottomed out and start the motor up, let it idle or go drive it so it gets warmed up ot hot, then set the idle mixtures screws(slowly, one at a time) to see if you can make the motor run out of idle fuel by turning the idle mixtures screws in all the way to closed If it still runs then you need to adjust the front and REAR throttle plates so the fronts are adjutsed to be ONLY on the idle circuit, not the transfer or main circuits Let us know what you find out
I set the secondary plates to .020" from being fully seated as per Holley recommendations. As far as the primaries go, are you referring to the fast idle screws? I can only think of the fast idle screw and/or curb idle screws being able to adjust the opening of the primaries at idle...
If so, don't you set the fast idle screw to give you around 1500 RPMs at engine start?
Forgive me here as I am a young guy and still just trying to learn these carburetors.
I also noticed the engine wasn't idling down well when you revved it...seemed to hang around 1200-1300RPM in neutral. The only way to get it idle down was to put her in gear and let the tranny stall it down a bit.
I did some investigating and it appears the accel pump lever is being contacted too tightly from the throttle lever....preventing the throttle from quite returning to rest when the engine was revved. I have no idea if this would impact the issues I have been having but I will adjust this a bit and see if it helps.
