Please help diagnose this noise..... #1194528
03/10/12 04:31 PM
03/10/12 04:31 PM
Puyallup, WA
StealthWedge67 Offline OP
Puyallup, WA
I drove the car the other day for the first time in a while, and was frightened to hear a clattering noise in the drivetrain. It is a clatter that seems to be active when even a slight load is on the motor, but not evident at idle or cruise. It seems to be coming from the tranny / bellhousing area. I immediately thought it was a flex-plate bolt coming loose, and clattering against the inspection cover (thats exactly what it sounds like), but when I pulled the inspection cover I found all bolts to be tight and happy. There is a slight rotational mark on the inspection cover, but none of the flex-plate bolts seem to have reciprical marking and that mark on the flex plate could be from years gone by ????.
Everything else seems to look good. I checked the starter bolts and all the bell housing bolts, all are tight. Rear tranny mount seems good. Motor has a Moroso solid mount on the driver side and a rubber stock mount on the passenter side, both look fine and the motor does not appear to be moving.
What else could be making a clattering sound that would sound just like inspection cover clatter????
Re: Please help diagnose this noise..... [Re: StealthWedge67] #1194529
03/10/12 05:07 PM
03/10/12 05:07 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Does the car need to be moving or does it do it while
sitting still
Re: Please help diagnose this noise..... [Re: MR_P_BODY] #1194530
03/10/12 05:17 PM
03/10/12 05:17 PM
Amherst,NY
challengermike Offline
Amherst,NY
flexplate cracked?
Re: Please help diagnose this noise..... [Re: StealthWedge67] #1194531
03/10/12 06:16 PM
03/10/12 06:16 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
what kind of flexplate are u using?? stock one's crack. i'd look there first. seeya.
Re: Please help diagnose this noise..... [Re: rickraw] #1194532
03/10/12 07:24 PM
03/10/12 07:24 PM
Puyallup, WA
Puyallup, WA
Stock flexplate. never did it while sitting, more when the car was moving. I'll look the flex-plate over real good. Where do they tend to crack?
Re: Please help diagnose this noise..... [Re: StealthWedge67] #1194533
03/10/12 07:30 PM
03/10/12 07:30 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
seen them crack between the large openings
Re: Please help diagnose this noise..... [Re: rickraw] #1194534
03/10/12 08:00 PM
03/10/12 08:00 PM
Puyallup, WA
Puyallup, WA
Well, took a good look at the flex-plate. I don't see any cracks or issues. I think I'm going to go drive it without the inspection cover and see if I get the noise or not. If I don't, then at least I know where its at. If I still get it, then I know I'm barking up the wrong tree.
Re: Please help diagnose this noise..... [Re: StealthWedge67] #1194535
03/10/12 08:14 PM
03/10/12 08:14 PM
Delray beach, Florida
P
Performance Only Offline
P
might as well take a good look at the U-joints while your under there.
machine shop owner and engine builder
Re: Please help diagnose this noise..... [Re: Performance Only] #1194536
03/10/12 11:36 PM
03/10/12 11:36 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Sure sounds like a cracked flex plate the way you describe it. I have seen flex plates with hairline cracks that make alot of noise but you cant see it until you take it off. Good luck , Ron
Re: Please help diagnose this noise..... [Re: 383man] #1194537
03/11/12 01:14 AM
03/11/12 01:14 AM
Puyallup, WA
Puyallup, WA
Well, I took it for a drive with the inspection cover off, and the noise went away. Tried to reinstall it, immediate clatter. I can see where the bolts are hitting the cover, and it donned on me that the cover is original to the car, which originally had an 11" converter. There is a channel stamped into the cover that follows the path of the bolts, and with the 10" converter that is in it now, the bolts fall inside that channel.
However, I still don't understand why this would just all of the sudden become a problem. Could there be something going on with the converter or front pump that is pushing the converter forward?
Re: Please help diagnose this noise..... [Re: StealthWedge67] #1194538
03/11/12 01:31 AM
03/11/12 01:31 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
the pump can't push the converter out. if u have tons of crank end play, the bolts would hit the block first. i don't use a cover, so i don't know if the bolts can hit the cover before it hits the block. check ur end play. i beleive 10 thou is the max. seeya.
Re: Please help diagnose this noise..... [Re: StealthWedge67] #1194539
03/11/12 02:20 AM
03/11/12 02:20 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The conv could be balloning... just put a washer
under the 2 bolts to move the cover out or just bow
it out some
EDIT
Like said... check the end play on the crank
