Re: Engine Freeze ??
[Re: Scamp408]
#1194402
03/10/12 01:36 PM
03/10/12 01:36 PM
Posts: 3,344 Central TX
roe
Central TX
I wouldn't risk it, a couple of bottles of 50/50 antifreeze are a lot cheaper than a new motor
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
[Re: Scamp408]
#1194404
03/10/12 03:28 PM
03/10/12 03:28 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
Lay an incandescent drop light under the hood on top the motor, near a water passage. Enough heat will transfer from the bulb to keep it from freezing at 32.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: Scamp408]
#1194406
03/10/12 04:41 PM
03/10/12 04:41 PM
RapidRobert
Would it be convenient for you to drain the block?
