CH 28 air cleaner options #1194333
03/10/12 09:54 AM
03/10/12 09:54 AM
6T4 Polara Offline OP
Have a friend with a 440 CH 28 intake and carter carbs.
What options are there for air cleaners.
Changed out the original Mopar intake and oval cleaners but the fit with the new intake is tight on the oval cleaners.
Re: CH 28 air cleaner options [Re: 6T4 Polara] #1194334
03/10/12 11:02 AM
03/10/12 11:02 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
there's the two assemblys edelbrock offers. i don't think the cast aluminum will fit under the hood. there are units from the rod&custom guys, and two 6 3/8" air cleaners will probably fit. nothing for the mopar oval but there was a company called classic haulage that made a round unit similar to a street hemi.
Re: CH 28 air cleaner options [Re: 6T4 Polara] #1194335
03/10/12 01:01 PM
03/10/12 01:01 PM
AndyF Online content
AndyF  Online Content
I like the Edelbrock air cleaner. That is what I used on this 505 engine. I think I upgraded to an K&N air filter.
I also make a throttle linkage kit for the CH-28. Part number is AR287. Mancini Racing or Hughes Engines will have the throttle linkage.
Re: CH 28 air cleaner options [Re: 6T4 Polara] #1194336
03/10/12 01:10 PM
03/10/12 01:10 PM
Missouri
bb74swngr Offline
mopar addict
bb74swngr  Offline
mopar addict
Missouri
My stuff is all used and sorta hillbilly but it may give ya some ideas...:) Picture 1-4...
Number one is using the Moroso air pan and two 6+" air filters
Number two is just two 6+" air filters
Number three is a stock look with base modified
Number four original mock up with Eddy Elite
Hope this helps...Russ:)
BigBlock 74 Swinger
Re: CH 28 air cleaner options [Re: 6T4 Polara] #1194337
03/10/12 01:12 PM
03/10/12 01:12 PM
Missouri
bb74swngr Offline
mopar addict
bb74swngr  Offline
mopar addict
Missouri
Number 2...
BigBlock 74 Swinger
Re: CH 28 air cleaner options [Re: 6T4 Polara] #1194338
03/10/12 01:13 PM
03/10/12 01:13 PM
Missouri
bb74swngr Offline
mopar addict
bb74swngr  Offline
mopar addict
Missouri
Number 3...
BigBlock 74 Swinger
Re: CH 28 air cleaner options [Re: 6T4 Polara] #1194339
03/10/12 01:14 PM
03/10/12 01:14 PM
Missouri
bb74swngr Offline
mopar addict
bb74swngr  Offline
mopar addict
Missouri
Number 4...
BigBlock 74 Swinger
Re: CH 28 air cleaner options [Re: bb74swngr] #1194340
03/10/12 01:50 PM
03/10/12 01:50 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Hit up PaintItBlack, member here...I got this from Steve and had to hack it up because the original DualQuad measurements didnt fit the CH28. I am no body man but the cutting of the fiberglass, resetting, and painting took me about 36 hours. Fits perfect with 1/2" aluminum necks to raise it a little off each carb so the linkages work properly. Also bought the K&N filter for it. Going to paint it Black (base) and Orange (lid) with "DUAL QUAD 440" in block letters on it
Sits perfect in the engine bay. Clears the 3spd wiper motor, clears my MSD dizzy. I havent finished painting it though but thats one alternative
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: CH 28 air cleaner options [Re: Pyper70] #1194341
03/10/12 01:53 PM
03/10/12 01:53 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
The only other alternative I liked (prior to the Six-Pack clone) setup was this one...Its the K&N Route 66 series. I believe retail the two air cleaners are about $550. I got them used on eBay for 200...still have them but wont make any use of them until I get a raised bulge hood for the car
Re: CH 28 air cleaner options [Re: AndyF] #1194342
03/11/12 09:33 AM
03/11/12 09:33 AM
Thanks for the replies.
