dumb lifter question #1194229
03/09/12 11:31 PM
03/09/12 11:31 PM
alaska,usa
9
9secondsatellite Offline OP
alaska,usa
i'm putting together a magnum 360 motor with the hydraulic roller cam. the lifters have a feed hole on one side. does it matter which direction it's positioned? oil hole on the cam side or the cylinder side? thanks for the help.
Re: dumb lifter question [Re: 9secondsatellite] #1194230
03/09/12 11:41 PM
03/09/12 11:41 PM
Maybe the oil hole should go into the oil galley, if it(link bars) will work with it that way
Re: dumb lifter question [Re: Cab_Burge] #1194231
03/10/12 12:00 AM
03/10/12 12:00 AM
alaska,usa
9
alaska,usa
no link bars. magnum motor. has the slip over retainers with the metal tensioner that bolts in the middle of the lifter galley.
Re: dumb lifter question [Re: 9secondsatellite] #1194232
03/10/12 12:50 AM
03/10/12 12:50 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Doesnt matter... you have a choice of 180*... both are right
Re: dumb lifter question [Re: MR_P_BODY] #1194233
03/10/12 01:23 AM
03/10/12 01:23 AM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
The holes need to point up...Towards the valley, or cam.
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: dumb lifter question [Re: Adobedude] #1194234
03/10/12 03:30 PM
03/10/12 03:30 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Seems to me I remember Mopar saying put the oil hole up towards the cam. When we replaced cams at the dealer I remember a paper coming with the lifters saying that. Ron
Re: dumb lifter question [Re: 383man] #1194235
03/10/12 03:38 PM
03/10/12 03:38 PM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
Re: dumb lifter question [Re: Adobedude] #1194236
03/10/12 03:43 PM
03/10/12 03:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I'll take your word on it... I never seen a paper
on it but maybe I missed it
Re: dumb lifter question [Re: MR_P_BODY] #1194237
03/10/12 04:23 PM
03/10/12 04:23 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
As a Mopar tech.Please Put holes up toward valley. If not you will have problems.
Re: dumb lifter question [Re: VernMotor] #1194238
03/10/12 04:30 PM
03/10/12 04:30 PM
alaska,usa
9
alaska,usa
thanks for the info guys. i'll be sure to face the holes towards the cam.
Re: dumb lifter question [Re: 9secondsatellite] #1194239
03/10/12 06:48 PM
03/10/12 06:48 PM
Indy
moparman89 Offline
moparman89  Offline
Indy
Interesting info here. I've built 50+ magnums with the lifter oil holes down (hole towards pistons). I've never had an issue.
School of Automotive Machinists Racing
Re: dumb lifter question [Re: moparman89] #1194240
03/10/12 08:13 PM
03/10/12 08:13 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Just copy this from the service book.
3.Install tappets and push rods in their original positions. Ensure that the oil feed hole in the side of the tappet body faces up (away from the crankshaft)
They come from the factory with paint marks on them. so you could see it as you put them in that the paint mark was up.
