Re: Rod bolt stretch gauges
[Re: Cab_Burge]
#1194200
03/10/12 04:20 PM
03/10/12 04:20 PM
Posts: 3,505 DFW
mr_340
DFW
Yep, did that. Manley says the stretch should be .0069"-.0073". Not quite in the middle, .0071" would have been the middle on the ARP2000 bolts. Here is a list of dimensions on the bolts out of the box(es).
New ARP Bolts Manley P/N 42391-1 Out of Box Checks Blue Bolts Red Bolts Rod # Thread Diameter Shank Diameter Thread Diameter Shank Diameter A 0.4320 0.3705 0.4313 0.3711 B 0.4314 0.3711 0.4310 0.3708 C 0.4312 0.3711 0.4313 0.3708 D 0.4307 0.3711 0.4314 0.3709 E 0.4315 0.3715 0.4309 0.3712 F 0.4304 0.3710 0.4303 0.3709 G 0.4317 0.3711 0.4312 0.3708 H 0.4307 0.3710 0.4307 0.3706 Cut for Wt. Reduction Free Length Hardness Free Length Hardness A 2.2204 44.0 2.2201 45.5 B 2.1650 45.5 2.1506 44.5 C 2.1842 47.0 2.1823 46.0 D 2.2453 45.0 2.2473 46.0 E 2.1654 44.5 2.1668 46.0 F 2.1465 45.5 2.1364 46.5 G 2.1483 47.0 2.1402 48.0 H 2.2460 49.5 2.2265 45.5 .0070” Stretch all bolts
Floyd Lippencott IV
[Re: mr_340]
#1194201
03/10/12 05:48 PM
03/10/12 05:48 PM
dartman366
Mt. Vernon, Ohio
I bought a Jegs house brand rod bolt stretch gage and immediately took it to work and had it run thru the calibration lab,,,guess what,, dead nuts thru the range, while not quite as nice as a lot of others it fit my purpose of doing this once every few years,,if I did this for a living then I would invest in a top notch checker.
[Re: dartman366]
#1194202
03/10/12 07:44 PM
03/10/12 07:44 PM
Posts: 2,091 Delray beach, Florida
Performance Only
i've got several different brands, ARP, Proform, BHJ, not sure what else. they all work just fine and they all read the same on the same bolt.
machine shop owner and engine builder
