B Body Master Cylinder Converson? #1194087
03/09/12 04:48 PM
03/09/12 04:48 PM
Northampton Pa
65 NSS 500 Offline OP
Northampton Pa
I wanted to see what master cylinder would fit in a stock replacement from a single reservoir to a double. I relaize I have to replumb the dual cylinder but I was hoping not to have to by a disc conversion set up. Its for a 65 coronet..
1965 Coronet 500 340 40+ Passon 4sp 12.90 2.6 60' street tires
Re: B Body Master Cylinder Converson? [Re: 65 NSS 500] #1194088
03/09/12 04:50 PM
03/09/12 04:50 PM
AndyF Offline
AndyF  Offline
Most anything will work if you want cast iron. I highly recommend going with the newer aluminum master cylinder though. Get the MC and the adapter plate from Mancini Racing or DoctorDiff.
Re: B Body Master Cylinder Converson? [Re: AndyF] #1194089
03/09/12 04:55 PM
03/09/12 04:55 PM
Sullivan, Ohio
Max Wedge Savoy Offline
Sullivan, Ohio
If your original setup is power you will need a manual brake firewall plate. After that I would get the 4 to 2 adapter and a new style MC. The bore size will matter if you use drum/drum, 2 piston disc/drum, 4 piston disc/drum, etc. Don't forget the proportioning valve for the front if you go disc/drum.
Re: B Body Master Cylinder Converson? [Re: Max Wedge Savoy] #1194090
03/09/12 06:10 PM
03/09/12 06:10 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
order 1 for a 4 wheel drum 67 b body
Re: B Body Master Cylinder Converson? [Re: 05dakota] #1194091
03/09/12 06:22 PM
03/09/12 06:22 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I use 69 - 70 C body masters.If its drum drum get one for that.Ive done quite a few conversions.My kids 62 300 with drums runs one as does my 65 with disc conversion.Both work great.His is 12 years and mine is probally 15.Rocky
Chrysler Firepower
