engine paint? #1193933
03/09/12 12:27 PM
03/09/12 12:27 PM
usa
lewtot184 Offline OP
usa
i need to match the street hemi orange on an engine and the current mopar color isn't close. i talked to a paint guy and he said he could match what i have in enamel. any of you guys do this? do i need a hardner and does it hold up? thanks.
Re: engine paint? [Re: lewtot184] #1193934
03/09/12 01:03 PM
03/09/12 01:03 PM
Ohio
LS-300 Offline
LS-300  Offline
Ohio
Think of it this way Rustolium is enamel. It hold up well.
1979 Chrysler 300 1968 Barracuda project
Re: engine paint? [Re: LS-300] #1193935
03/09/12 02:30 PM
03/09/12 02:30 PM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
What size and year of motor? If its a 71 340 I can give you a krylon paint code thats a dead match.
High Performance Mopar had an article on on painting engine with a gun. The key was using the right amount of paint 2.5 mils to be exact.They used PPG's Delstar with no primer. They cleaned and cleaned and cleaned it before painting using PPG 220 degreaser first then PPG 330 cleaner. Its the March 95 issue.
Re: engine paint? [Re: NV69B7RR] #1193936
03/09/12 04:50 PM
03/09/12 04:50 PM
usa
usa
its a '69 440 painted in '97. i need to paint the valve covers and oil pan.
