Ride Height #1193893
03/09/12 11:04 AM
03/09/12 11:04 AM
White Hall, Maryland
MD72 Offline OP
MD72  Offline OP
How do I measure "Ride Height" for a '72 Barracuda? And what is it for a stock set up?
Re: Ride Height [Re: MD72] #1193894
03/09/12 01:41 PM
03/09/12 01:41 PM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Factory ride ht is the difference between
from ground to bottom of lower control arm where it pivots, specificly use the adjuster arms bottom at that point.
from ground to the bottom of the lower ball joint.
Pictures and drawings in the shop manual and probably also in the MTSC at the Imperial club.org
Lots of info there.
Re: Ride Height [Re: Mattax] #1193895
03/09/12 10:00 PM
03/09/12 10:00 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Re: Ride Height [Re: MD72] #1193896
03/09/12 11:36 PM
03/09/12 11:36 PM
Make sure that the gas tank is full and all the tires are inflated properly, maybe add the weight in passenger you plan on hauling I add between 1/2 to one more inch in hieght for it to settle some later
