Mirada comes out of the box running hard after 4yrs.... #1193790
03/09/12 01:20 AM
03/09/12 01:20 AM
aZLiViN
J_BODY Offline OP
J_BODY  Offline OP
aZLiViN
My dad hauled his car down from sodak to my home in AZ. We planned on him running it at the March Meet and I had pre-entered him. Two weeks prior we destroyed the 340 while testing at Speedworld. We were going to go to Bakersfield either way, but with the entry already paid we decided to throw the Mirada in the trailer and just have as much fun as we could. The ole wore out j-bod did pretty good considering how long it had been sitting. I had run the valve at MaTS in 07 and changed the oil so it only had like 8 passes on it since parked. Fresh trans only had 16 passes, but the slicks are old as dirt, but it is what it is. Best pass to date for my junk. 9.93 and also ran a 9.98. The car does "look" the part with full cage, window net, etc... but that's about it. Had a blast and every pass all weekend had a 1.35 60ft time....except third round sunday where I redlit, but it wouldn't have mattered if I went perfect.....we blew the tires off it. Good times either way!
Re: Mirada comes out of the box running hard after 4yrs.... [Re: J_BODY] #1193791
03/09/12 01:23 AM
03/09/12 01:23 AM
aZLiViN
J_BODY Offline OP
J_BODY  Offline OP
aZLiViN
1st round.... just barely stabbed the brakes after catching my spot. WHEW! (i'm #279)
Re: Mirada comes out of the box running hard after 4yrs.... [Re: J_BODY] #1193792
03/09/12 01:26 AM
03/09/12 01:26 AM
aZLiViN
J_BODY Offline OP
J_BODY  Offline OP
aZLiViN
Round two.... I was the second car to the lanes and pulled aside for a possible byerun.... not to be, ended up racing a ranchero decorated with event win decals.... Left a little at the tree, but grabbed a fender early and he hit the brakes hard and I followed suit since i was out on him.
Re: Mirada comes out of the box running hard after 4yrs.... [Re: J_BODY] #1193793
03/09/12 01:27 AM
03/09/12 01:27 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That`s great.......great 60 foots too.
Re: Mirada comes out of the box running hard after 4yrs.... [Re: J_BODY] #1193794
03/09/12 01:28 AM
03/09/12 01:28 AM
aZLiViN
J_BODY Offline OP
J_BODY  Offline OP
aZLiViN
Hey NHRA!! I found all the people that didn't pop for Pomona tickets!!
Re: Mirada comes out of the box running hard after 4yrs.... [Re: J_BODY] #1193795
03/09/12 01:32 AM
03/09/12 01:32 AM
aZLiViN
J_BODY Offline OP
J_BODY  Offline OP
aZLiViN
the "been there got the picture" shot....
Re: Mirada comes out of the box running hard after 4yrs.... [Re: J_BODY] #1193796
03/09/12 01:34 AM
03/09/12 01:34 AM
aZLiViN
J_BODY Offline OP
J_BODY  Offline OP
aZLiViN
...and one more just because it's so damn cool! Famoso baby!!
Re: Mirada comes out of the box running hard after 4yrs.... [Re: J_BODY] #1193797
03/09/12 01:39 AM
03/09/12 01:39 AM
north cakalaky
I
instigator Offline
instigator  Offline
I
north cakalaky
BAD AZZZZ!.....I may have to pick your brain sometime on the front torsion bar sytem.....same thing in my Chrysler 5th AVE I picked up......throwing the ole turbo motor in that for a while!
A good friend and our company CPA has the Mirada in stock eliminator down here in NC...don't run nothing like that one does though....let's see sum motor pics..suspension pics!
65 Barracuda
All aluminum Indy HEMI with some boost!
COMING TO A TRACK NEAR YOU!
Re: Mirada comes out of the box running hard after 4yrs.... [Re: instigator] #1193798
03/09/12 01:50 AM
03/09/12 01:50 AM
Sunnyvale, CA
Jeepmon Offline
Jeepmon  Offline
Sunnyvale, CA
One day.. One day baby...
Re: Mirada comes out of the box running hard after 4yrs.... [Re: instigator] #1193799
03/09/12 02:03 AM
03/09/12 02:03 AM
aZLiViN
J_BODY Offline OP
J_BODY  Offline OP
aZLiViN
Front suspension is stock. Shocks are worn out which gives it a little quicker extension. I did eliminate the K member isolators and replaced them with steel rectangular tube. Rear is a ladder bar set up. Lowering the car with the ladder set up only allows a 10.5 slick to fit. It's "mini tubbed" up to the frame rail and the outer fender lip inside is rolled up. Engine.... well it looks pretty! Bunch of old school junk that we've freshened at least four times throughout it's lifecycle. It's at the "n'th" of being worn out in all aspects. Ultradyne mech cam (the old NF-69 .640 lift), Mopar Stage VI heads (thanks Dwayne!), M1 intake, Carb Shop 1050 98 square jets. 34 degrees total timing. Stock crank welded and cut to 4.15 stroke, LY rods, light Ross pistons, stock main caps, ARP main studs, stock block. shift at 5700, trap at 6200. We've shifted higher and ran more gear than the current 4.10 in it..... didn't matter much.
Re: Mirada comes out of the box running hard after 4yrs.... [Re: J_BODY] #1193800
03/09/12 03:58 AM
03/09/12 03:58 AM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
Very nice...Glad to see ya back out there. Now you can drag it up here and Steven can put it to good use for you until you need it again in four years
Re: Mirada comes out of the box running hard after 4yrs.... [Re: Al_Alguire] #1193801
03/09/12 04:03 AM
03/09/12 04:03 AM
Arizona
Chris'sBarracuda Offline
Arizona
That sucker runs..
Chris..
Re: Mirada comes out of the box running hard after 4yrs.... [Re: Chris'sBarracuda] #1193802
03/09/12 09:27 AM
03/09/12 09:27 AM
tboomer Offline
tboomer  Offline
Nice!! What does that thing weigh?
Re: Mirada comes out of the box running hard after 4yrs.... [Re: tboomer] #1193803
03/09/12 11:15 AM
03/09/12 11:15 AM
Windsor ,Ca.
K
Keith Richards Offline
K
Windsor ,Ca.
Congrats, saw you running the car on Bangshift. Great wall hanger you got there too, I have one from there with are '68 road runner from 2002 hanging in our stairwell, yeah, been that long since I last raced the March Meet hopefully in the next year or two we will again. Problem is they keep having points races same weekend at the track soon to be formerly known as Infineon.
Re: Mirada comes out of the box running hard after 4yrs.... [Re: Keith Richards] #1193804
03/09/12 11:25 AM
03/09/12 11:25 AM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Congrats!
Had a friend I was supposed to meet out there but I couldn't make it.
He has a Ranchero in HR, but it's not the one you ran, he went to third round too. Said there were another 4 rounds after that!
Re: Mirada comes out of the box running hard after 4yrs.... [Re: J_BODY] #1193805
03/09/12 11:57 AM
03/09/12 11:57 AM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
Cool! Didn't expect to see LY rods and a welded crank in that combo.
Re: Mirada comes out of the box running hard after 4yrs.... [Re: tboomer] #1193806
03/09/12 03:21 PM
03/09/12 03:21 PM
aZLiViN
J_BODY Offline OP
J_BODY  Offline OP
aZLiViN
3180 with me in it Ted. Could still pull some weight out if I wanted. Love the power windows though...
Re: Mirada comes out of the box running hard after 4yrs.... [Re: J_BODY] #1193807
03/09/12 04:15 PM
03/09/12 04:15 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
J....glad you had a great time...now I have a partner to beat the March Meet drum with...NO ONE preps a track like the crew at Famoso...its a thing of beauty. EVERYONE who wants to have their best pass ever needs to make the trip out west sometime. The weather was awesome....the company was great....hope you and your dad become regulars to the EVENT.
BTW...Ranchero R755 is Eric "King of HOT ROD" Christianson...you beat a Famoso legend ....he just returned from a 2 year hiatus...way to go !
My Dart quarter panel and slick make an appearance in this awesome video.
http://bangshift.com/blog/awesome-march-...and-spills.html
Re: Mirada comes out of the box running hard after 4yrs.... [Re: Chassisman] #1193808
03/09/12 04:46 PM
03/09/12 04:46 PM
aZLiViN
J_BODY Offline OP
J_BODY  Offline OP
aZLiViN
Dang!! I feel like an azz not mentioning the great MM info and hospitality provided by you Ron! Answered all my questions and really helped me not jumping into this event blind. I'm so glad you stressed how important it was to stay at the track....with the crowds it would have been difficult to get back in. Just wish I had a camera handy when you were cruising the pimp-mo-kart through the vendor area with that load of hard "working" girls! ....yeah I know, they're "dancers"!
The Chassimans pit area is well equipped!
Re: Mirada comes out of the box running hard after 4yrs.... [Re: J_BODY] #1193809
03/09/12 04:52 PM
03/09/12 04:52 PM
Chowchilla,ca
Chassisman Offline
Chassisman  Offline
Chowchilla,ca
We'll find out soon how much DEJA VU Showgirls is sponsoring me for. Sounds like a nice tidy sum so far...but until the contract is signed we'll see.They want the car....golf cart...and trailer wrapped...plus they want me to race Calif..Vegas...and Az at every event possible.
Like I said...glad you enjoyed yourself and was glad that you felt at home and took advantage of our Bangshift HQ...LOL...hopefully you got plenty to eat Friday night....we served 145 plates.
