Re: Hard to push Dakota
[Re: bobs69]
#1193718
03/08/12 10:56 PM
03/08/12 10:56 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
are your brake hoses the original rubber lines if so I have seen them start to come apart on the inside and not let all the pressure off may be something to check
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: dusturbd340W5]
#1193719
03/08/12 10:59 PM
03/08/12 10:59 PM
Posts: 75 southwest pa
bodyworks racing
southwest pa
When is the last time you did any welding on your truck ?
68 ROADRUNNER 440 HORSE POWER IS HOW FAST YOU HIT THE WALL TORQUE IS HOW FAR YOU TAKE THE WALL WITH YOU
[Re: bodyworks racing]
#1193722
03/08/12 11:48 PM
03/08/12 11:48 PM
dusturbd340W5
Kissimmee Fl.
galling the rear output shaft support is a common problem on a 904/727 BUT I highly doubt you caused it welding on the car just bad timing,they where just looking for a fall guy.
#1193723
03/09/12 12:35 AM
03/09/12 12:35 AM
Posts: 1,260 New Mexico
Adobedude
New Mexico
Oh crap, don't tell me that...I just put an 8 point in my Dakota, the only thing I worried about was the fuel lines...
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: bobs69]
#1193724
03/09/12 07:01 AM
03/09/12 07:01 AM
Posts: 20,655 in a cattle trailer down by th...
Guitar Jones
My Duster with a 904 and an 8.75 with a spool was really hard to push too. The trans was fine and I had aftermarket discs on all four corners. It didn't seem to affect how it ran though, 10.50's with a 340 so I'm not sure why. The Scamp has the same rear and trans in it but it's a little easier to push but I think it's only because it's about 400 pounds lighter.
[Re: racerx]
#1193729
03/09/12 01:52 PM
03/09/12 01:52 PM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
This may not help,but I have noticed cars with spools in them or harder to push.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
[Re: MRMOPAR622]
#1193730
03/09/12 04:34 PM
03/09/12 04:34 PM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
Around a corner yes , in a straight line no.
Also to the op , the sprag in the trans is also part of the problem , it's easy to turn the driveshaft in one direction , the sprag is slack , the other way the sprag tightens up and it spins the geartrain in the trans . I don't remember which direction is easier than the other. Jack up the rear and grab a tire, turn one way then the other , it'll be easy one way and not in the other.
[Re: racerx]
#1193731
03/09/12 04:44 PM
03/09/12 04:44 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
So sixpack was that the reason you were having a high rolling resistance ?
both issuses caused the same sortof problems. the brake problem i started to notice at the race track, the car would start getting slower then you would start to smell the brakes till it got so bad it wouldnt move. that was the rubber brake line problem
the next problem was the same thing, started getting slower at the track. a couple days later, went to push the car a few feet and almost lost a nut. after some trouble shooting i figured it was in the trans
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: JohnRR]
#1193732
03/09/12 06:51 PM
03/09/12 06:51 PM
Posts: 43,259 Bend,OR USA
Cab_Burge
Forward is easy (counter clockwise looking forward under the car)backwards (clockwise) is harder, low ratio helical cut low gear sets make it worst
[Re: Cab_Burge]
#1193733
03/09/12 06:59 PM
03/09/12 06:59 PM
Guitar Jones
Yeah, makes sense now as I had a low gear set in my 904.
[Re: Cab_Burge]
#1193734
03/09/12 07:03 PM
03/09/12 07:03 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Either way it turns it gets hard to push... 1 tire has to go farther so they are both dragging(1 is going a longer distance and the other is trying to go the shorter distance but they TRY to average out so they BOTH drag)
