Re: 68 Barracuda headlight ?
[Re: Gary Robbins]
#1193713
03/09/12 01:49 AM
03/09/12 01:49 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
The 'clips' are already on the adjuster screws when you buy them, if you buy the 'correct' screws. As shown in this photo from megapartsusa.com, the adjuster screws for 1968-1971 two headlight setups like '68 Barracuda have a white plastic (or nylon) part with a very thin metal cage around it that pops in and locks in the square hole in your fender.
(Looks like one of the plastic parts is backwards in this photo.)
Be careful: Once the caged plastic part clicks in, you ain't gonna get it out again without destroying it. That is, unless there is a special tool or secret trick I don't know about.
If in the photo, the three screws on the left are correct, you have to insert them from the rear of the square hole, and there is very little room back there. You'll need to remove the galvanized bucket that the headlight nests in. Or maybe even grille parts?
IMO, just about everything about the design and workings of the Barracuda make good, logical sense. EXCEPT these headlight adjusters. A crummy design, seems to me.
[Re: kentj340]
#1193714
03/09/12 01:54 AM
03/09/12 01:54 AM
kentj340
Cut and Shoot, TX
Here's the square hole the adjusters lock in. The scratch marks around it show how much trouble I had destroying the old ones to get them out.
[Re: kentj340]
#1193715
03/09/12 12:24 PM
03/09/12 12:24 PM
kentj340
Cut and Shoot, TX
Here's the other square hole that's much harder to get behind...rotsa ruck.
[Re: kentj340]
#1193716
03/09/12 09:19 PM
03/09/12 09:19 PM
Posts: 803 Idabel,Oklahoma
Gary Robbins
Idabel,Oklahoma
Thanks very much,thats them:
