Re: MOST FLOW OUT OF A SET OF -1S [Re: Randy..] #1193651
03/10/12 11:15 PM
03/10/12 11:15 PM
single fogger. and i am putting twin 75mm turbo's on them.
My 527 brcket motor made 845 HP at N/A at 7000 RPM with a set of CNC ported 440-1 by Jeff that flowed 370 at .600 to .800 with a single 1050 Dominator on a Indy 440-3 intake Twin turbos with a intercooler and EFI out to make a lot more than that
Re: MOST FLOW OUT OF A SET OF -1S [Re: Cab_Burge] #1193652
03/10/12 11:44 PM
03/10/12 11:44 PM
Bama
Randy.. Offline OP
Randy..  Offline OP
Bama
it wont be to wild, under .720 lift cam and pump gas, looking for 900/950 to the tire with 3.55 gears.
Re: MOST FLOW OUT OF A SET OF -1S [Re: cudabin] #1193653
03/11/12 01:27 PM
03/11/12 01:27 PM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
N/A my 557ci made 955hp (Methanol injection)w/ 345cc CNC'd -1's that flow 382 at .800 these are Jeff's from Modern's program.
Cam is .875" (less lash and deflection)so i am opening them up as far as reasonable
Car weighs 2,850 and at 4,000 foot DA ran 8.80's, but there is more left in the combo...
If you want more than that N/A you need a better head IMO.
Cheers,
Arnie
Arnie,
Shift point? Trans? Have you ever looked at your combo, and thought, "Darn, I should have went with a better head", or are you happy??
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: MOST FLOW OUT OF A SET OF -1S [Re: MoparBilly] #1193654
03/11/12 01:46 PM
03/11/12 01:46 PM
Saskatchewan, Canada
cudabin Offline
cudabin  Offline
Was shifting at 7,400 rpm as peak HP came at 7,200rpm.
i did not get many passes last year due to transmission problems (727) and broken valve springs.
just put a set of Victory 2.25" Titanium valves and PSI 1224 Dual damperless springs on the -1's and will try a higher shift point this year...
Happy with the -1's as my chassis and my budget can't really handle anymore power...
Bang for the buck, I don't think it is worthwhile to upgrade to a better head for my program.
Cheers,
Arnie
67 Cuda 8.48@ 158.7 mph 1.18 60' 2,600 DA(so far...) 70 Super Bee 440 Six Pack 4-speed. 13.2 @ 104 Stock exhaust/Street tires.
