crankshaft machining? #119352
09/11/08 03:56 PM
09/11/08 03:56 PM
OK
70SWGR Offline OP
70SWGR  Offline OP
OK
What does it cost to have a crank turned or polished?
Re: crankshaft machining? [Re: 70SWGR] #119353
09/11/08 04:24 PM
09/11/08 04:24 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
in your area or mine ?
Re: crankshaft machining? [Re: 70SWGR] #119354
09/11/08 04:31 PM
09/11/08 04:31 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
simply call a couple local machine shops. Most will just cut .o1o rather than polish. you can polish it your self with some emery paper and a leather shoe lace. wrap the emery paper around the journal then the shoe lace around that twice. then just rotate the paper by pulling alternatly in either direction. this is an old school trick and assumes that you have mic'ed the journals yourself and do not need to machine them.
Re: crankshaft machining? [Re: JohnRR] #119355
09/11/08 08:24 PM
09/11/08 08:24 PM
OK
70SWGR Offline OP
70SWGR  Offline OP
OK
Any area I was just curious how expensive it costs now.
Re: crankshaft machining? [Re: 70SWGR] #119356
09/11/08 08:47 PM
09/11/08 08:47 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
$100.00 to $125.00 to have it index ground, oil holes chamfered, and journals polished in these parts. Balancing is extra.
Re: crankshaft machining? [Re: Neil] #119357
09/12/08 10:22 AM
09/12/08 10:22 AM
dogdays Offline
dogdays  Offline
A stone bargain. You could triple that where I live for that level of detail.
R.
