Negative Battery Cable - Alum. Hemi Heads #1193145
03/07/12 10:21 PM
03/07/12 10:21 PM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
Guys, I have a alum cylinder heads on a hemi in a 70 Challenger (see the pics). I am trying to come up with a negative cable that will reach my battery that has the correct heavy duty hemi battery connections. I ordered the factory replacement and its way short. Any one have any ideas......
Re: Negative Battery Cable - Alum. Hemi Heads [Re: faud88] #1193146
03/07/12 10:25 PM
03/07/12 10:25 PM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
Re: Negative Battery Cable - Alum. Hemi Heads [Re: faud88] #1193147
03/07/12 10:27 PM
03/07/12 10:27 PM
OHIO
faud88 Offline OP
faud88  Offline OP
OHIO
Last one
Re: Negative Battery Cable - Alum. Hemi Heads [Re: faud88] #1193148
03/07/12 10:31 PM
03/07/12 10:31 PM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
I put mine on the block as I did not want to put it on the Alum. Small blocks Heads
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Negative Battery Cable - Alum. Hemi Heads [Re: 340SIX] #1193149
03/07/12 11:35 PM
03/07/12 11:35 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
Not sure if your wanting stock or not but i just wanted mine to not clutter the motor up
i went to auto zone got a 32" neg cable ran it down between the battery and rad support in the hole between battery tray and rad support back behind the power stearing pully and onto the bottom bolt going into the power stearing bracket/ water pump housing/ block
you dont even notice it at all
we got alum heads on our hemi also
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Negative Battery Cable - Alum. Hemi Heads [Re: faud88] #1193150
03/08/12 12:31 PM
03/08/12 12:31 PM
Cab_Burge Online work
Cab_Burge  Online Work
Hook it up, connect it to, the 3/8 bolt by the freeze plug on the front of the head That or onto the closest header bolt
