7290 or 1350 u-joint for a dana 60 build? #1193047
03/07/12 08:50 PM
03/07/12 08:50 PM
elmira ny
hp340nos Offline OP
hp340nos  Offline OP
elmira ny
im upgrading to a dana 60 from an 8 3/4.current u-joint is the 7290 size,should i go to a 1350?or is the 7290 plenty? 88 dakota 3340#,340 stroker roughly 470 hp. street/strip.what stock mopars came with the 1350 727 slip yoke and 1350 joints on the driveshaft?
Re: 7290 or 1350 u-joint for a dana 60 build? [Re: hp340nos] #1193048
03/07/12 09:04 PM
03/07/12 09:04 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
If you are starting from scratch you might as well use 1350 u-joints. A Viper is the only mopar that used a 1350 slip yoke with a 727 type spline and diameter.
Re: 7290 or 1350 u-joint for a dana 60 build? [Re: 446acuda] #1193049
03/07/12 09:17 PM
03/07/12 09:17 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
go with the 1350
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: 7290 or 1350 u-joint for a dana 60 build? [Re: hp340nos] #1193050
03/07/12 09:57 PM
03/07/12 09:57 PM
organ
maximum entropy Offline
organ
either would be fine, but make sure you get solid forged u joints regardless.
Re: 7290 or 1350 u-joint for a dana 60 build? [Re: maximum entropy] #1193051
03/07/12 11:35 PM
03/07/12 11:35 PM
Greensburg, Pa
Mpetros Offline
Mpetros  Offline
Greensburg, Pa
5-811x Spicer if 7290 U-Joint
or 5-1350x Spicer if You go with 1350 U-Joint
If You decide to go 1350.. and You cant find the Yoke Local to You
I Stock the 1350 Spicer 727 Trans Yoke PT# 3-3-3931
Mark
www.GreensburgMachine.Com
Re: 7290 or 1350 u-joint for a dana 60 build? [Re: hp340nos] #1193052
03/08/12 03:05 AM
03/08/12 03:05 AM
I used a 7290 driveshaft end with the stock 7290 to 1330(maybe 1310, not sure of the proper Dana Spicer part numbers ) Hi Po solid center stock type U joint Mopar used that same type U joint on the stock production muscle cars back in the day that came with the Dana 60, 4 speed hemi cars and all of them that where assembled with the Dana 60 rear ends That Dana 60 pinion yoke has U bolt as the U joint retainer, not straps and bolts like the 8 3/4 have. All that being said if your starting from scratch including the driveshaft go with the 1350
Re: 7290 or 1350 u-joint for a dana 60 build? [Re: Cab_Burge] #1193053
03/08/12 11:29 AM
03/08/12 11:29 AM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Everything nowadays is 1350
2011 Drag Pak Challenger
