Dakota Idle Issue #1193015
03/07/12 07:54 PM
03/07/12 07:54 PM
San Antonio, TX
CurYellowBird Offline OP
San Antonio, TX
My truck is a 96' Dodge Dakota 3.9L 2WD. The truck will start up but won't idle or run unless I hold the gas pedal down.
So far, I have already replaced the IAC (idle air control valve) and the battery is really weak so I have that on a charger.
Any idea as to what else it may be? It's not sputtering or anything when I hit the gas, it just won't idle. Not sure if its the tps or something else.
Project War Bird: 1971 Plymouth Roadrunner 383 4 speed with air conditioning GY3 Curious yellow All original
Re: Dakota Idle Issue [Re: CurYellowBird] #1193016
03/07/12 08:16 PM
03/07/12 08:16 PM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
TPS is cheap and easy to replace. I'd give it a shot.
Scott
1969 Super Bee, 383/4 speed
Re: Dakota Idle Issue [Re: StukaJU87] #1193017
03/07/12 10:27 PM
03/07/12 10:27 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Put a new battery in and your problems will likely be solved. The low battery voltage is wacking out the PCMs learned adaptives to control the engine idle. Clean the throttle butterflies also.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
