master cylinder adapter to 2-bolt #1192912
03/07/12 03:14 PM
03/07/12 03:14 PM
Parsons (SouthEast) Kansas
funkyjbp Offline OP
mopar addict
funkyjbp  Offline OP
mopar addict
everyone, will the four-to-two bolt adapter fit on a truck master cylinder? i have a nearly new four bolt booster on a 77 truck and i want to use an aluminum two bolt master off of a later model. thanks for your information and advice. JP in the land of Oz!
71 SWB, 413 77 SWB, 318 92 SWB, 5.2 magnum 79 Macho Short bed, 318 03 stratus coupe R/T too many others not on the road!
Re: master cylinder adapter to 2-bolt [Re: funkyjbp] #1192913
03/07/12 07:23 PM
03/07/12 07:23 PM
AndyF Offline
AndyF  Offline
Yes, it should fit. The pushrod should also fit but you'll want to check that carefully to make sure you have full travel without bottoming out. The adapter isn't really designed to work with a booster. It is designed for manual brakes.
