Difference between the 426 Hemi and 426 Street Wedge??? #1192829
03/07/12 01:02 PM
03/07/12 01:02 PM
Iowa, US
oldsklharo Offline OP
Iowa, US
Ok guys, I got some great advice and education in my other thread on the differences of the 392 and 426 Hemis.........Now can we discuss the differences between the 426 Hemi and the 426 Street Wedge???
I have also found a Street Wedge that I may or may not try and buy. Any info would be much appreciated
Thanks, Mike
Re: Difference between the 426 Hemi and 426 Street Wedge??? [Re: oldsklharo] #1192830
03/07/12 02:17 PM
03/07/12 02:17 PM
60+ HP difference, two carbs VS one, Hemi head VS wedge and the list goes on
Re: Difference between the 426 Hemi and 426 Street Wedge??? [Re: Cab_Burge] #1192831
03/07/12 02:24 PM
03/07/12 02:24 PM
Iowa, US
Iowa, US
So can you put a single carb intake and Hemi heads on a SW and basically have a 426 Hemi?
Are the blocks and lower end the same?
Re: Difference between the 426 Hemi and 426 Street Wedge??? [Re: oldsklharo] #1192832
03/07/12 02:32 PM
03/07/12 02:32 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
The 426 wedge is no closer to being a hemi motor then say a 413 400 440 383 the only thing the two motors share is number of cubic inches
the 426 based hemi is its own beast you cant even swap the cam 383,400,413,426w to a hemi
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Difference between the 426 Hemi and 426 Street Wedge??? [Re: toplescuda] #1192833
03/07/12 02:36 PM
03/07/12 02:36 PM
Iowa, US
Iowa, US
Cool, thanks for the info.
That's all I was really wanting to know
Re: Difference between the 426 Hemi and 426 Street Wedge??? [Re: toplescuda] #1192834
03/07/12 02:42 PM
03/07/12 02:42 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
The difference being a 426 wedge is just a 440 with a smaller bore. The 426 wedge and the 426 hemi do share the same bore/stroke, take the same crank dimensions, etc. So you COULD put a set of 426 hemi pistons into a 426 wedge block and you COULD put a 426 hemi cam into a 426 wedge block. However that would all be useless because you can't put the 426 hemi heads on the 426 wedge block. The Hemi block has holes cast in the block where the exhaust pushrods go through. In a hemi, the exhaust pushrods come up through the block deck, through the coolant jacket, go through the head gasket, etc where on a wedge they don't. The top row of head bolts is also different, with the Hemi having the top row located further up, in an area not cast into a wedge block. Hemis also had oil drains cast into the block at each outer corner of the cylinder head mounting face, this area is not there on a wedge block. There was a company (stage v) that used to make Hemi heads to fit the wedge block, but with the availability of aftermarket hemi blocks, nobody really has a need for them these days.
Then of course hemis had cross bolted main caps, two bolts going up the bottom like a wedge, but also two bolts doing in from the side of the block.
Re: Difference between the 426 Hemi and 426 Street Wedge??? [Re: oldsklharo] #1192835
03/07/12 03:10 PM
03/07/12 03:10 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
From what I know:
Blocks share same bell housing pattern, water pump housing, and oil pump mounting. Block is cross drilled for the mains, MW is not. Cranks will interchange, but the flange pattern at the flywheel is different. Cam is different. A MW cam may fit, but the MW pattern is for EIIEEIIE where the hemi is EIEIEIEI for intake and exhaust accuation.
Heads and intake are obvious. Exhaust manifolds or headers are different due to valve arrangment. I think the distributor is interchangable. Engine mounts are different.
Thats what I recall off the top of my head.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: Difference between the 426 Hemi and 426 Street Wedge??? [Re: DaytonaTurbo] #1192836
03/07/12 03:11 PM
03/07/12 03:11 PM
Kirkland, Washington
Pacnorthcuda Offline
No, think about it, a hemi is EIEIEIEI the Wedges are EIIEEIIE
Re: Difference between the 426 Hemi and 426 Street Wedge??? [Re: Pacnorthcuda] #1192837
03/07/12 03:14 PM
03/07/12 03:14 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
They sell hemi profile cams for wedges.
Re: Difference between the 426 Hemi and 426 Street Wedge??? [Re: Pacnorthcuda] #1192838
03/07/12 03:17 PM
03/07/12 03:17 PM
Manitoba, Canada
Manitoba, Canada
Yes but the cam physically fits. As I said this would be useless to you to do in a block that won't accept hemi heads.
Re: Difference between the 426 Hemi and 426 Street Wedge??? [Re: DARTH V8Я] #1192839
03/07/12 03:17 PM
03/07/12 03:17 PM
Yes they do, that refers the grind. The cams are configured differently, by neccessity.
Re: Difference between the 426 Hemi and 426 Street Wedge??? [Re: Cab_Burge] #1192840
03/07/12 03:22 PM
03/07/12 03:22 PM
Desert Tracker
HYPER8oSoNic Offline
Desert Tracker
Cab and Daytona Turbo are 100% correct. The 426 Street Wedge and the 426 Hemi share the basic foundations in engine block dimensions.. BUT ..
are designed differently from the head/intake and up. In a nutshell, the HEMI has a fortified RB block designed for higher output/higher rpm usage
due to the deep breathing Hemi heads. The 426 Street Wedge is a basic 4 barrel wedge motor, sort of like a .060-over 413, 9 to 1, maybe 9 to 5 comp motor. Nothing special, but still a good
basis for a GOOD street motor!! Cab's right about the 60+ HP difference and that's putting it mildly! At best there's a power difference of over 100HP! (426 Hemi in optimal tune - HEMI tuners were not many back then)
"Stupidity is Ignorance on Steroids"
"Yeah, it's hopped to over 160" (quote by Kowalski in the movie Vanishing Point 1970 - Cupid Productions)
Re: Difference between the 426 Hemi and 426 Street Wedge??? [Re: Pacnorthcuda] #1192841
03/07/12 03:34 PM
03/07/12 03:34 PM
Desert Tracker
Desert Tracker
The HEMI grind (for the 383/440 motors) is designed with the duration and
lobe lift of the 426 HEMI, but on the wedge motor intake/exhaust pattern. Also the intake centerline and overlap are slightly different, due to the wedge-type clyinder head design.
Re: Difference between the 426 Hemi and 426 Street Wedge??? [Re: oldsklharo] #1192842
03/07/12 03:47 PM
03/07/12 03:47 PM
central Florida
VL21 Offline
VL21  Offline
central Florida
I have had 3 64 Plymouths with the 426S, and every one of them was a slug. Well, maybe not slugs, but a strong 383 would walk them, and I have had more than a few 64 383s too.
Problem was the 426S was a mild motor, used the 413 New Yorker cam, had no better heads than the 383, etc.
With better cam, heads and intake would have been a different story.
Still, a factory 426 car would be a damn good starting point, more for the other stuff that came with the engine package. Think bigger (11") brakes, cop car(as good as it was) suspension (with front sway bar), HD cooling, and glam factor.
Wish my 65 Coronet convertible was a 426S pkg...
It takes gasoline to interest me.
Re: Difference between the 426 Hemi and 426 Street Wedge??? [Re: VL21] #1192843
03/07/12 04:39 PM
03/07/12 04:39 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
I have heard of people welding in bosses inside the lifter valley to take the hemi studs, and putting a hemi head, and hemi cam in a 440. Dont know if its true, but I have heard that a few times from different people from other parts of the country. Id say it would be worth a shot if ya have a few "junk" 440 blocks laying around to test it out on. Im a decent enought cast welder that Id give it a shot. Heck you probly wouldnt really even need the extra bolts for head torque unless you were going for all out compression.
Kasey
Re: Difference between the 426 Hemi and 426 Street Wedge??? [Re: Moparnut426] #1192844
03/07/12 06:19 PM
03/07/12 06:19 PM
Manitoba, Canada
Manitoba, Canada
Kasey
I did talk to one guy on the phone one time who said he did just that. He told me about how he used to do it back in the 70's and 80's when you just couldn't find or afford a replacement hemi block. He described taking a 413 block, boring it .060 over to take stock 426 hemi pistons. Said he used the steel shim head gaskets and never had an issue not using the top row of head bolts. Said the hardest part was the exhaust pushrods. Needed to grind clear into the water jacket for clearance. Then heat up a piece of steel red hot and black smith it into shape and weld it in. Said the intake pushrods cleared with a small amount of grinding and needed to thread in some drain tubes from the corners of the head to the oil pan. He said back then you could get a junk 413 and a set of used stock bore hemi pistons for peanuts. Said he'd build one and run the hell out of it until the block started to let go, then build another one. Said he hasn't done one in years since the availability and affordability of repro hemi blocks. Would still be an interesting experiment.
Re: Difference between the 426 Hemi and 426 Street Wedge??? [Re: Pacnorthcuda] #1192845
03/07/12 06:33 PM
03/07/12 06:33 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Yes that is true but one could physically put a hemi cam in a wedge and vise versa , it won't run but you can put it in there
Re: Difference between the 426 Hemi and 426 Street Wedge??? [Re: Moparnut426] #1192846
03/07/12 06:37 PM
03/07/12 06:37 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Kasey
... you seriously believe that ? ...
There is more than just installing the bosses , you first have to grind off the currnet casting bumps because the hemi bolt is about half a hole up from the wedge threaded hole , you have to do something about the lower oil returns at both the front and back of the block on each bank back to the oil pan.
Then there is the exhaust pushrod tunnels , grind the 440 block and you hit water ...
Re: Difference between the 426 Hemi and 426 Street Wedge??? [Re: JohnRR] #1192847
03/07/12 07:03 PM
03/07/12 07:03 PM
Desert Tracker
Desert Tracker
Kasey
There is more than just installing the bosses , you first have to grind off the currnet casting bumps because the hemi botl is about half a hole up from the wedge threaded hole , you have to do something about the lower oil returns at both the front and back of the block on each bank back to the oil pan.
Well said John.
Re: Difference between the 426 Hemi and 426 Street Wedge??? [Re: HYPER8oSoNic] #1192848
03/08/12 12:50 AM
03/08/12 12:50 AM
Eastern WA
P
ProStock1320 Offline
P
Eastern WA
Doesn't Stage V Engineering make Hemi conversion heads to use on a wedge block? I understand there is way more to it than that, but they are out there, right?
