synthetic in older HP engines? #1191874
03/05/12 11:59 PM
03/05/12 11:59 PM
ALBERTA CANADA
CUDA8U Offline OP
CUDA8U  Offline OP
ALBERTA CANADA
i heard once that the older engines burned up synthetic oil,any truth to this and what do you use?
thanks for all the help guys,i'm just getting back into older vehicles in 15+ yrs
Re: synthetic in older HP engines? [Re: CUDA8U] #1191875
03/06/12 12:14 AM
03/06/12 12:14 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
An engine is an engine. Synthetic oil doesn't know the difference and neither do the engines. I use syn in my 410 stroker with no leaks or oil useage.
Re: synthetic in older HP engines? [Re: stumpy] #1191876
03/06/12 08:34 AM
03/06/12 08:34 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
This is weird... but i once switched to Mobil 1 synthetic in my old high-mile 440 crop-duster (Charger). Did a full oil change. That thing used to go through oil almost a liter a week. I only put the Mobil 1 in there because i had 10 free liters and i wanted to see if there was a difference.
It cut oil consumption by more than half.
I have NO idea how this is even possible. I started buying Mobile 1 for it when it needed oil (little over every 2 weeks now), and it ended up being about the same price i was paying before.
Anyways, that aside, it seemed to run a bit better. The exhaust coming into the interior through the holes in the floor and trunk had a distinctly different smell too...
Re: synthetic in older HP engines? [Re: Pale_Roader] #1191877
03/06/12 09:03 AM
03/06/12 09:03 AM
Palmyra, NY
63stabamatic Offline
Palmyra, NY
I have stayed away from synthetic in my older flat-tappet cam engines mainly because small oil leaks get much worse with synthetic.
Re: synthetic in older HP engines? [Re: 63stabamatic] #1191878
03/06/12 11:07 AM
03/06/12 11:07 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
the "myth" as I understand it and where it comes from...is that synthetics tend to be thinner, and flow better. the side effect is that seals and gaskets that are getting hard and brittle, now allow the thinner oil to seep though them and cause external leaks. I suppose this could apply to valve seals and worn out rings as well, causing the engine to burn more oil.
Another belief, is that the synthetics do a much better job at washing the inside of the engine, and they wash any built up sludge on the non-moving surfaces, again, allowing the thinner oil to reach the worn out gaskets.
take your pick, but there must be some truth to the myth, surely it can't be coincidental that so many old engines started leaking miraculously right after switching to synthetics?
**Photobucket sucks**
Re: synthetic in older HP engines? [Re: 70Cuda383] #1191879
03/06/12 11:57 AM
03/06/12 11:57 AM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
Is the motor built with tight clearances, or loose like back in the old days?
If loose you may find consumption goes up. If it a new build with new seals close clearances, etc. I'd say go for it. If you don't like it, switch back.
Re: synthetic in older HP engines? [Re: 70Cuda383] #1191880
03/06/12 11:59 AM
03/06/12 11:59 AM
dogdays Offline
dogdays  Offline
Yes, but you're talking about ancient history, like 30 years ago. The seal issue was an issue in the early 80s, isn't anymore.
Strangely enough, my '64Dog's rampant oil use slowed down noticeably when I started feeding it a steady diet of my friend's 5000-mile-old Mobil 1. It still uses so much oil it's a joke, but it's now more like 150 miles per quart rather than 100. I have no explanation why.
The three most dangerous words: "I have heard".
R.
Re: synthetic in older HP engines? [Re: dogdays] #1191881
03/06/12 03:28 PM
03/06/12 03:28 PM
Michigan, USA
ramman5600 Offline
ramman5600  Offline
Michigan, USA
Depending on your build and parts used I would do some research about zinc content (or lack there of).
-C
Re: synthetic in older HP engines? [Re: 70Cuda383] #1191882
03/06/12 03:37 PM
03/06/12 03:37 PM
Eugene, Oregon
Secret Chimp Offline
Eugene, Oregon
Synthetics are thinner when cold. The oil film on some synthetics is actually thicker compared to other oils of the same weight (i.e. Redline).
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: synthetic in older HP engines? [Re: Secret Chimp] #1191883
03/06/12 08:11 PM
03/06/12 08:11 PM
BDW Online content
BDW  Online Content
Unless you plan on extending your oil changes, I really don't see the benefit.
For the occasional driver that puts 2-3K or less per year, seems like a waste of money to me.
Is anyone really going to drive 3yrs before changing the oil?
Re: synthetic in older HP engines? [Re: BDW] #1191884
03/06/12 09:19 PM
03/06/12 09:19 PM
Ohio
dobie Offline
dobie  Offline
Ohio
I bought my current motor back in 2008. We freshened it up a bit and did some top end work, but that was it. Since ive had it i run Mobil 1 15-50 plus a bottle of comp cams break in additive. No issues at all and no leaks. I also havent changed the oil since 2010, but thats partly due to not driving it the last 2 years.
1968 Plymouth Road Runner 383 4 speed
Re: synthetic in older HP engines? [Re: dobie] #1191885
03/06/12 09:46 PM
03/06/12 09:46 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
You know I've read a bunch of these threads on here and beyond the usual from the guys that make a living on this stuff.. The real issue was'nt the leaky seals, or the undisputed fact it does lubricate better...The issue with a straight synthetic was the prolonged storage/dry start conditions that's created by the syn oil sheeting off the parts leaving virtually no protection like the dino based oils that clung to the parts....And so the reason for the warning to all collector car guys that have cars sitting around for extended periods of time stating it's probably not the best oil for that scenario..
Re: synthetic in older HP engines? [Re: screamindriver] #1191886
03/07/12 06:43 PM
03/07/12 06:43 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Oh boy! Another popular myth, the "cling" myth.
Folks, a vast majority of fully synthetic motor oil found on the market today IS DINO BASED; pumped from within the earth and highly refined. Do a Google search for Group III base stocks to learn more.
The other synthetics, those commonly referred to as true synthetics or PAO/Esters, when formulated properly have no issue with cling because they generally have a fair dose of ester oil in the range of 5-to-25%. Ester oil has a high polarity to be positively attracted to the metal surface. PAO alone not so much.
Oh! And not a guy that makes a living selling oil.
For more info, below are a hand full of articles from Thomas Schaefer, Retired VP Sales, Hatco Corp.
Synthetic Lubricants - link
Esters In Syntehtic Lubricants - link
What's In Your Motor Oil - link
Fuel Economy and Synthetics - link
Re: synthetic in older HP engines? [Re: CompSyn] #1191887
03/07/12 06:56 PM
03/07/12 06:56 PM
toronto canada
69chargeryeehaa Offline
toronto canada
have you ever taken one apart?
i have seen the "cling" issue on synthetics on a tranny i took apart (honda 5-spd), literally drove it, and within 5 hours it was apart and laid out on cardboard, and virtually no oil, parts almost dry (mobil 1 10W30 synthetic), vs pulling a spare trans that was almost empty sitting for years, and oil was on everything, i just needed one part (shift fork from the donor trans with reg oil), and it completely soaked the cardboard for a week!!!
so I'm not really convinced, seeing that made me
Re: synthetic in older HP engines? [Re: 69chargeryeehaa] #1191888
03/07/12 07:26 PM
03/07/12 07:26 PM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
Are you talking about fresh oil in a freshly rebuilt transmission verses sludge, varnish and moisture contaminated build-up in an old transmission that sat around for years? Wouldn't one have to compare two freshly rebuilt transmissions, one with good, clean dino juice versus one with good, clean synthetic to have a relevant comparison?
Don't get me wrong, there are lots of very competent and talented mechanics out there, but when one thinks they see something with only one snap shot in time, the assumptions fly and the myths abound.
