Re: I NEED CARB ADVISE 77 RAMCHARGER /6 4 SPEED?
[Re: ScottSmith_Harms]
#1191763
03/06/12 02:52 AM
03/06/12 02:52 AM
Posts: 9,857 Cambridge Idaho
RUMBLON
Cambridge Idaho
Nothing wrong with that carb, just needs a proper restoration
Scott Im into the truck for $300.00 as is, the carb restoration would cost more than that Im trying to do this on the cheap.
RUMBLON
#1191764
03/06/12 02:58 AM
03/06/12 02:58 AM
RUMBLON
Cambridge Idaho
Scott, I know this carb is a Carter, but any idea what one so I can check on a rebuid kit? Every one calls it a BBD?
#1191766
03/06/12 03:52 AM
03/06/12 03:52 AM
Posts: 817 Eugene, Oregon
Secret Chimp
Eugene, Oregon
You can have the Carter BBD off of my 67 318. Never gave me any trouble.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
#1191767
03/06/12 01:54 PM
03/06/12 01:54 PM
Posts: 14,610 Not2farfromNashville, TN
Rug_Trucker
No hint on what is wrong with it? Throttle shaft usually needs to be bushed. The tops warp and leak. It appears to be a super six BBD. They flow less cfm than a 318 model Different idle circuits. The slant carb has a bent PCV fitting, thicker front choke "wall" I love those carbs! there is a Holley that that Mopar used stock when Carter went out of business. If you rebuild it make sure you get a 6 cylinder carb to intake gasket. There is a difference!!! www.slantsix.orgThere is a video on youtube from Chrysler. It doesn't completely play.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
[Re: RUMBLON]
#1191770
03/06/12 02:22 PM
03/06/12 02:22 PM
Posts: 75,058 U.S.S.A.
JohnRR
U.S.S.A.
What number is on the tag?
CARB TAG
Could you please post a crapier picture ?
How about reading it and posting the numbers .
The screws you circled are for the idle mixture
[Re: JohnRR]
#1191771
03/07/12 04:54 PM
03/07/12 04:54 PM
RUMBLON
Cambridge Idaho
CARB TAG
sorry thats all I had on file that I could access with out being home and taking a new pics. I am off saturday and will get back on it and get some pics of it.
[Re: RUMBLON]
#1191772
03/08/12 12:36 PM
03/08/12 12:36 PM
Rug_Trucker
That's a super six carb. I don't need the tag to tell that. Order a kit for that year truck. The kits cover the 318 carbs too. Peel the old gaskets off and match them. There is subtle differences.
[Re: Rug_Trucker]
#1191773
03/08/12 12:48 PM
03/08/12 12:48 PM
Rug_Trucker
Make sure you order the /6 base gasket. It may take a few days to get one.
