Ok...it's winter so...take your bets! #1191728
03/05/12 10:47 PM
03/05/12 10:47 PM
Pittsburgh PA
Eric Offline OP
Eric  Offline OP
Pittsburgh PA
Wafflebatter and I have been racing together for better than a decade. We have each had two different cars and have been close in ET with both for years each faster than the other at points.
Well this year for various reasons both of us are stepping things up a bit.
The stats:
Wafflebatter-
27 Aero T Roadster..421 SBC.. 14-1..227 AFR's CNC ported...AED 1000cfm... .680 roller cam...Jesel 1.6's..UCC 5800 converter...glide...4.56's...approx race weight 1800#
Previous best... 1/8th- 5.52@123...with me driving..cough...cough 1/4-?...maybe Doug will chime in. Best 60ft. 1.18.
The Arrow-
499 lowdeck...12.5-1..CNC ported SR's...650 Comp...Harland Sharp 1.5's...850 Ray Murray...UCC 5400 converter...glide...4.56's...approx race weight 2275#
Previous best... 1/8th 5.65@121 1/4 9.04@149..this was at two different tracks. Best 60ft 1.23.
So...one of my winter changes is going to 4 wheel disc from MustangII and Dana drum..I feel this will free up both weight and major rolling resistance.
So any guesses?....I'm thinking if I to alcohol and maybe a roller cam I might stand a chance. I figure he will be close to a 5.20 1/8th mile ride with the weight loss going from his iron heads to the AFR's...and the bigger roller. I'm gaining better than a point of compression and ported heads. Also the brake change.....Watchcha guys think?...I think I might see 5.40's.
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Ok...it's winter so...take your bets! [Re: Eric] #1191729
03/06/12 01:12 AM
03/06/12 01:12 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
I honestly don't think the brake upgrade will make it any faster. I thought drums actually roll easier because the shoes get retracted by the springs. Although I think the brakes are a good upgrade as rotating weigh reduction, I don't see it worth a lot of ET. Now a roller cam and alky might get you a little bit.
You car seems to pull real good to the 1/8 and then peter out, not sure what's going on there? Seems like there are a couple of tenths in a 1/4? Picking up 2/10's in the eighth at your ET is not going to be small changes..
Re: Ok...it's winter so...take your bets! [Re: Bigcube] #1191730
03/06/12 01:18 AM
03/06/12 01:18 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Did not see the ported heads are new for next year the first time I read it! That should help a bunch with a properly matched roller to go with the new heads.
Re: Ok...it's winter so...take your bets! [Re: Bigcube] #1191731
03/06/12 08:32 AM
03/06/12 08:32 AM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
and at least a 1050 dominator...those iron brakes weigh a ton...those are what?..53lbs...
Re: Ok...it's winter so...take your bets! [Re: Eric] #1191732
03/06/12 11:06 AM
03/06/12 11:06 AM
NC
440Jim Offline
440Jim  Offline
NC
You have your work cut out for you, since you weigh almost 500 lbs more than his ride.
I think the porting, etc. will make nice gains.
The idea of alky is a good one. Especially with the price of race gas.
Re: Ok...it's winter so...take your bets! [Re: 440Jim] #1191733
03/06/12 11:30 AM
03/06/12 11:30 AM
MR_P_BODY Offline
MR_P_BODY  Offline
weight is a major factor
Re: Ok...it's winter so...take your bets! [Re: Eric] #1191734
03/06/12 12:52 PM
03/06/12 12:52 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Eric, I have a buddy that runs a very similar set up to your's, only his in a Omni/Charger and has a Dominator on it. He runs 5.50s only turning it 6200. He made the switch to alchol two years ago and said it was like a different car. I forget what it picked up but most of it was in the 60'.
Re: Ok...it's winter so...take your bets! [Re: Bigcube] #1191735
03/06/12 01:47 PM
03/06/12 01:47 PM
Backwater, PA
bwdst6 Offline
Bob George Racing #1 Fan
bwdst6  Offline
Backwater, PA
Lightweight car, low on power, a lot of gear, etc…
This post is available in double vision where drunk.
Re: Ok...it's winter so...take your bets! [Re: bwdst6] #1191736
03/06/12 02:34 PM
03/06/12 02:34 PM
Pittsburgh PA
Eric Offline OP
Eric  Offline OP
Pittsburgh PA
On the 9.04 pass it ran 5.75 in the 1/8th ....
5.75 x 1.5723 = 9.0407.....
Re: Ok...it's winter so...take your bets! [Re: Eric] #1191737
03/06/12 03:16 PM
03/06/12 03:16 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
That is more inline, I assumed both times were from the same run
Re: Ok...it's winter so...take your bets! [Re: Eric] #1191738
03/06/12 03:51 PM
03/06/12 03:51 PM
Backwater, PA
bwdst6 Offline
bwdst6  Offline
Backwater, PA
Sure, but a 1.23 60’ is really good for a low 9 sec car!
Re: Ok...it's winter so...take your bets! [Re: Bigcube] #1191739
03/06/12 03:55 PM
03/06/12 03:55 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Eric,
You should mention that your old combo was a pump gas low compression dished piston with 75cc unported SRs.
Re: Ok...it's winter so...take your bets! [Re: B G Racing] #1191740
03/06/12 05:46 PM
03/06/12 05:46 PM
Pittsburgh PA
Eric Offline OP
Eric  Offline OP
Pittsburgh PA
Eric,
Ya...what he said!!!...
Re: Ok...it's winter so...take your bets! [Re: Eric] #1191741
03/06/12 06:30 PM
03/06/12 06:30 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Eric,
Oh man - Eric is stepping up to racing gas - this going fast is money money money
Re: Ok...it's winter so...take your bets! [Re: Eric] #1191742
03/06/12 06:45 PM
03/06/12 06:45 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
The stats:
Wafflebatter-
Previous best... 1/8th- [Email]5.52@123...with[/Email] me driving..cough...cough 1/4-?...maybe Doug will chime in. Best 60ft. 1.18.
The Arrow-
Previous best... 1/8th [Email]5.65@121[/Email] 1/4 [Email]9.04@149..this[/Email] was at two different tracks. Best 60ft 1.23.
If you decide on going to alcohol you may want to crank that compression up some to take advantage of running it. Crank it up to 15-1 and she'll love it. Who's cnc program are you going with and what are your before and after numbers. I have a nice 690 lift roller sitting here that you are welcome to try if you want to. Are you going with the Indy intake?
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Ok...it's winter so...take your bets! [Re: DoubleD] #1191743
03/07/12 11:24 AM
03/07/12 11:24 AM
Pittsburgh PA
Eric Offline OP
Eric  Offline OP
Pittsburgh PA
Eric,
Alky's cheaper than pump gas
Re: Ok...it's winter so...take your bets! [Re: Eric] #1191744
03/07/12 03:50 PM
03/07/12 03:50 PM
Fredonia,NY
W
wafflebatter Offline
W
Fredonia,NY
I think 5.20's will be stretching it for my ride, maybe we should just have a heads up race to see if you go the alky route, then I guess I will have to follow suit
Re: Ok...it's winter so...take your bets! [Re: wafflebatter] #1191745
03/07/12 05:17 PM
03/07/12 05:17 PM
Pittsburgh PA
Eric Offline OP
Eric  Offline OP
Pittsburgh PA
...[Edited by Moparts - Family Friendly Site - Keep it clean]!!
Re: Ok...it's winter so...take your bets! [Re: Eric] #1191746
03/07/12 05:33 PM
03/07/12 05:33 PM
Fredonia,NY
W
W
Fredonia,NY
Re: Ok...it's winter so...take your bets! [Re: wafflebatter] #1191747
03/08/12 11:54 AM
03/08/12 11:54 AM
Pittsburgh PA
Eric Offline OP
Eric  Offline OP
Pittsburgh PA
So no ET predictions for either??
