360la rocker arm torq specs?
#1191713
03/05/12 10:21 PM
03/05/12 10:21 PM
Posts: 36 Goodyear, AZ
Redleg
Goodyear, AZ
I read that the rocker shaft bolts are supposed to be torqued to 20lbs,just double tapping with moparts, is this correct?
1977 D-150 Warlock 360/727
2021 Challenger T/A 392/M6
Its pronounced Dirte'
Re: 360la rocker arm torq specs?
[Re: Redleg]
#1191714
03/06/12 12:02 PM
03/06/12 12:02 PM
RapidRobert
(2) diff manuals show 15. 20 will not hurt you
[Re: RobX4406]
#1191716
03/06/12 07:31 PM
03/06/12 07:31 PM
Posts: 6,167 Maryland
GO_Fish
Maryland
That's right, doesn't take much to snap them off (and the '69 FSM for my 340 had the torque wrong (30 ft lbs, IIRC). I should have known a bolt that small couldn't take 30 ft. lbs.
E-berg sells a hardened version that is slightly longer also to allow another thread or three to bite deeper into the head.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
[Re: GO_Fish]
#1191717
03/08/12 12:22 PM
03/08/12 12:22 PM
Redleg
Goodyear, AZ
Yeah a lot of places online state 30ft lbs. But I snapped one of the bolts that tight... and they are o ly grade 5, I bought grade 8 replacements. There a thread or two lo Ger so ill try 20lbs
[Re: Redleg]
#1191718
03/08/12 12:42 PM
03/08/12 12:42 PM
RapidRobert
best would be to go the recommended torque for a grade 8 bolt in that dia. You need the right amt (not too much not too little) of torque on the internal/external thread interface to get a certain amt of constant stretch/tension to hold the item (rocker arms) in place. Any manual should have a torque chart for std grade 8 bolts or ask at the place you purchase them. torque the shaft down level. I lightly hand tighten em till they touch and the shaft is perfectly horizontle then center 1/4 turn then near right 1/4 turn then near left of center 1/4 turn then far right 1/4 turn then far left 1/4 turn then back to center 1/4 turn & so on. Resist the urge to go more than 1/4 turn no matter how loose some are as the springs are compressed diff amts. You're goal is to draw the shaft down perfectly horizontle then when it's down bring all 5 up to the proper torque spec. Cleaned threads/lightly lubed w WD40 works for me and a straightened coat hanger horizontle to keep the pushrods lined up under the arms
