stainless or steel fuel lines?
#1191640
03/05/12 08:36 PM
03/05/12 08:36 PM
Posts: 1,144 wellington ohio
68-scatpack-rt
In thin ice
In thin ice
wellington ohio
hello all. i'm getting ready to restore my entire fuel system on my 68 coronet rt. they system is cobbled together now and i'm going to use a spectra tank and straps.
my question is this: do i use the stainless steel lines and pickup or should i stay with the original style steel?
th car is kept in a non heated attached garage and is well kept.
i'm thinking of using finelines as they are local to me and seem to have a good reputation.
thoughts.
unions....the folks who brought you the weekend!
Re: stainless or steel fuel lines?
[Re: 68-scatpack-rt]
#1191641
03/05/12 09:11 PM
03/05/12 09:11 PM
Posts: 1,032 Ohio
dobie
Ohio
I went with stainless lines from Right Stuff, also local here in Ohio. Im using their lines for my fuel and brake systems. They've been installed since 2008 and no issues yet, and 0 leaks.
1968 Plymouth Road Runner
383 4 speed
#1191645
03/06/12 01:21 AM
03/06/12 01:21 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Go stainless, do it once, do it right....sure it's a PITA to bend/rebend or flare....use the proper tubing wrenches to tighten the flare nuts, add some oil or liquid teflon to the treads to ease tighting as stainless likes to gall, I replace ALL the lines in a car with stainless, sure some guys claim the steel is fine, not going to drive the car often,no rust, yada, yada, yada, maybe on the outside, but inside the line?...brake fluids, and esp higher blends of E-85 fuel absorb water/moisture Do what you want, but I've had more issues with rusty steel lines over the decades, than any with stainless
[Re: DAYCLONA]
#1191646
03/06/12 07:57 AM
03/06/12 07:57 AM
68-scatpack-rt
In thin ice
In thin ice
wellington ohio
thanks guys! i was worried about the stainless leaking. i'm going to replace the entire system from the fuel cap to the carb so all my fittings will be new and i hope the stainless will seat as such. i was leaning toward stainless because of corrosion and now i think i'll go that route. have a good day, rob
[Re: JohnH]
#1191648
03/06/12 12:22 PM
03/06/12 12:22 PM
Posts: 299 East Brunswick, NJ
finadk
East Brunswick, NJ
I just went through the same thing for my brake and fuel lines. I ended up going with the NiCopp brand, it is a nickel-copper alloy that has the strength and structural integrity of steel lines, but is more corrosion resistant and easier to bend than plain steel or stainless. Here is the site: http://www.agscompany.com/automotive/brake-fuel-transmission-lines/nicoppThey also make the green coated Poly-armor brand that is also easier to benc, and less expensive than the NiCopp. I bought mine online at Autozone usig the discount coupons to save 15%.
Scott
1956 Dodge Custom Royal Lancer (408 Stroker, 4 Wheel Disc Brakes, Rack & Pinion, 6 speed)
2002 Dodge Ram 1500 Quad Cab
1976 Corvette
