boring X-block? #1191628
03/05/12 03:35 PM
03/05/12 03:35 PM
canada
jp15 Offline OP
jp15  Offline OP
canada
Just got a new to Me virgin X- block and am courious as to how much bore these can safely take?( tryed a search on this but nuthing showed for me).
Thanks Jim
Re: boring X-block? [Re: jp15] #1191629
03/05/12 03:37 PM
03/05/12 03:37 PM
Renton Washington
Triple Threat Offline
Renton Washington
Have it sonic checked, thats the only way to know.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: boring X-block? [Re: jp15] #1191630
03/05/12 09:20 PM
03/05/12 09:20 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Mine was only good to 4.06 for a nitrous motor maybe 4.10 for n/a. 2 cylinders had pretty bad core shift.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: boring X-block? [Re: jp15] #1191631
03/05/12 09:29 PM
03/05/12 09:29 PM
AndyF Offline
AndyF  Offline
I've sonic checked a few X blocks for customers. Those blocks are usually pretty thick but Ma Mopar was a little lax in the QC dept back in the day. So you really have to have each block sonic checked before you make any decisions on overbore size.
If you don't have access to a sonic checker then just bore it to the next available ring size and call it good. Leave the walls as thick as possible.
Re: boring X-block? [Re: AndyF] #1191632
03/05/12 09:55 PM
03/05/12 09:55 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
all I can say is when I got mine from Kent Ritter he told me he had never seen 1 that wouldn't go 4.100 but the best way is to sonic it.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: boring X-block? [Re: AndyF] #1191633
03/05/12 09:58 PM
03/05/12 09:58 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
Sunset racecraft sonic checked mine, it had some core shift front to back.After cussing and discussing it we offset bored the passenger side about .050 to the front. With a bore size of 4.125 the thrust and non thrust are .250-.300, between the cylinders is about .120-.150 w/ one spot about .110. I've hard blocked it w/ a tall fill about 1.250-1.500 from the top.I'll use .030 offset cyl dowels to re center the heads. I ordered the pistons to match thanks to Rod at BPE. Rod is also supplying on of his big stroker cranks to go with this.
Re: boring X-block? [Re: DavidDean] #1191634
03/05/12 10:51 PM
03/05/12 10:51 PM
canada
jp15 Offline OP
jp15  Offline OP
canada
Thanks for sharing your experience guys. Hoping to go with a 4.100 with a 4.125 ultra lite crank for 435+ ci.
Jim.
Re: boring X-block? [Re: jp15] #1191635
03/05/12 11:40 PM
03/05/12 11:40 PM
Lubbock,TX
DavidDean Offline
DavidDean  Offline
Lubbock,TX
Who's crank and how light?
Re: boring X-block? [Re: DavidDean] #1191636
03/06/12 02:49 AM
03/06/12 02:49 AM
canada
jp15 Offline OP
jp15  Offline OP
canada
Kings,weight around 40lbs compared to the 60lbs 4.00incher I have now
Jim.
Re: boring X-block? [Re: jp15] #1191637
03/06/12 03:19 AM
03/06/12 03:19 AM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
Jim what does a King crankshaft like that cost?
Re: boring X-block? [Re: 340_Dart] #1191638
03/06/12 07:05 AM
03/06/12 07:05 AM
canada
jp15 Offline OP
jp15  Offline OP
canada
His 43lb is $1950.00 and the 39lb,which I,m planning on going with is $2400.00.
And $1780.00 for rods.
Jim.
