Who's good for crank work? #1191588
03/05/12 02:10 PM
03/05/12 02:10 PM
Chicago
curbman68 Offline OP
Chicago
I need some work done on my crank and the guy I have used before seems to no longer be in business (Precision Crank in Detroit) so I'm looking for someone else. The crank I have has a flat fueler type flange on the back and I need an indexing ring put on it for the flywheel. Any recommendations on who to use?
Re: Who's good for crank work? [Re: curbman68] #1191589
03/06/12 02:56 PM
03/06/12 02:56 PM
DRAG-ULA Offline
DRAG-ULA  Offline
Moldex in Redford MI
www.moldexcrankshaft.com
1970 Imperial, Low & slow daily driver
1973 Chrysler T&C
1948 Dodge B1 pickup - perpetual project
Re: Who's good for crank work? [Re: curbman68] #1191590
03/06/12 03:53 PM
03/06/12 03:53 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
i would think any competent machinist with a lathe could perform that operation
Re: Who's good for crank work? [Re: curbman68] #1191591
03/06/12 04:19 PM
03/06/12 04:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Are you referring to the lip that is sticking out
on the back.... have a ring machined up and press
it in... tack weld it if you want
Re: Who's good for crank work? [Re: MR_P_BODY] #1191592
03/06/12 05:02 PM
03/06/12 05:02 PM
Chicago
Chicago
on the back
Yes, that is what I need, sounds like it's no big deal then. Excellent! I did call Moldex, they said they are in the process of moving, won't be up and operating for a couple weeks. Anybody know what happened to Precision Crank and John Kaminsky, nice guy and excellent work.
Re: Who's good for crank work? [Re: curbman68] #1191593
03/06/12 05:20 PM
03/06/12 05:20 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
Adney performance crankshaft call him at
586-549-7557
Re: Who's good for crank work? [Re: W5DART66] #1191594
03/06/12 06:40 PM
03/06/12 06:40 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
The ring is NO big deal at all. I have even made one myself on a 340 crank. It had all that stuff cut off it for some crazy circle track idea that didnt work, I made one for the kid when I was in college, and made it about a .002 press fit, and then we tig welded it in. As far as I know its still in the, more than likely blown up, but still in the crank. Dirby car....
