date coded block #119126
09/11/08 08:48 AM
09/11/08 08:48 AM
Huntertown, IN U.S.A
abodyfan Offline OP
abodyfan  Offline OP
To date code a engine does the date on the engine have to be 6 months prior to build date or does it have to be only a month prior? I was wondering trying to find date coded engine for my 70 Duster 340 with a build date of March 24, 1970.
1971 Dodge Demon 340 4-speed 1970 Plymouth Duster FM3 340 727 1968 Dodge Dart GT Convertible
Re: date coded block [Re: abodyfan] #119127
09/11/08 08:53 AM
09/11/08 08:53 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
6 months ??? First off the IMPORTANT DATE is the ASSEMBLY DATE of the block. I haven't looked at 70 340 cars to see how close but I have seen many 69 big block B bodies and the assembly date of the engine has been within DAYS of the SPD , my 69 dart 383 GTS included , casting dates have been as close as a couple weeks before the assembly date thoug I have only seen as close as 3 weeks . My own personal 69 Bee has the assembly date of the original block one day AFTER the SPD of the car .
I'll stop there before some uptight numbers guys gets his PANTIES all in a bunch .
Re: date coded block [Re: JohnRR] #119128
09/11/08 09:41 AM
09/11/08 09:41 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Post a pic of the assembly date and your cars SPD and we can see how close your block is.
Re: date coded block [Re: ScottSmith_Harms] #119129
09/11/08 09:43 AM
09/11/08 09:43 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
More info
Re: date coded block [Re: ScottSmith_Harms] #119130
09/11/08 09:44 AM
09/11/08 09:44 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Here's where to look
Re: date coded block [Re: ScottSmith_Harms] #119131
09/11/08 12:11 PM
09/11/08 12:11 PM
abodyfan Offline OP
abodyfan  Offline OP
I haven't found a block yet. I have some parts guy looking. I wanted to make sure before I bought anything.
Re: date coded block [Re: abodyfan] #119132
09/11/08 12:31 PM
09/11/08 12:31 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Here's another block I have, I don't have a pic of the assembly number but It's probably somewhere around when your car was built.
Re: date coded block [Re: abodyfan] #119133
09/11/08 12:38 PM
09/11/08 12:38 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
the 340 in my challanger was cast in June 1969 for a vehicle SBD of Dec 1969. Assy date on the engine was late Nov 1969
a buddies 1968 Coroent R/T has it's original block also with an assy date of 1 day after the cars SBD
Re: date coded block [Re: gtx6970] #119134
09/11/08 12:42 PM
09/11/08 12:42 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
My 70 Challenger R/T vert has an engine assembly date the day after the scheduled production date as well...And a casting date two weeks prior...The rear axle pumpkin was also assembled the same day as the SPD & then the housing was assembled the next day...Sounds like lots of cars didn't follow the scheduled time table...
Re: date coded block [Re: abodyfan] #119135
09/11/08 12:49 PM
09/11/08 12:49 PM
AndyF Offline
AndyF  Offline
Ma Mopar had horrible inventory control which is one reason they were headed for Chapter 11 back in the 70's. It isn't unusual to find blocks with more than a year between casting date and assembly date. The typical spread is usually a few weeks but there is no "magic" time frame. It could be most anything on a Mopar. Remember, it wasn't built in a Toyota plant where things run on time, it was built by Chrysler.
Re: date coded block [Re: AndyF] #119136
09/11/08 06:00 PM
09/11/08 06:00 PM
dogdays Offline
dogdays  Offline
This just keeps coming up over and over, doesn't it? Chrysler built cars to sell, not to restore. Inventory control? Bah! Find the part and make it work. There's a reason they almost went belly up back in the day.
R.
Re: date coded block [Re: ScottSmith_Harms] #119137
09/11/08 09:11 PM
09/11/08 09:11 PM
abodyfan Offline OP
abodyfan  Offline OP
The sbp date of my car is 288721.
Re: date coded block [Re: abodyfan] #119138
09/11/08 10:49 PM
09/11/08 10:49 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Where did you come up with that SPD? It should be a 3 digit code, post a pic of your fender tag and I'll help you on it.
Re: date coded block [Re: abodyfan] #119139
09/11/08 10:53 PM
09/11/08 10:53 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Re: date coded block [Re: Alaskan_TA] #119140
09/11/08 10:57 PM
09/11/08 10:57 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yeah I saw that Berry, it's that last number he posted that made me ask
Re: date coded block [Re: ScottSmith_Harms] #119141
09/12/08 07:58 AM
09/12/08 07:58 AM
abodyfan Offline OP
abodyfan  Offline OP
Here's the pic of the fendertag.
Re: date coded block [Re: abodyfan] #119142
09/12/08 08:07 AM
09/12/08 08:07 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
is this ad not garnering the proper response ?
Re: date coded block [Re: JohnRR] #119143
09/12/08 08:58 AM
09/12/08 08:58 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
MAN! Have enough paint on that tag? Makes it a bit tough to read without a 10 minute photoshop endeavor. Anyway, it appears to have 324 on it so your initial March 24, 1970 seems to check out.
