Pics of leaf spring slider install #1191364
03/04/12 11:44 PM
03/04/12 11:44 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Hey everyone,
Just wondering if anyone can post some pics of how they installed their rear sliders for their leaf springs. I want to just weld them underneath the frame (below the hole where the rear shackles go) but im not sure if this is ok or if I have to make them a part of the frame rail...used to have pics but cant find them for the life of me
Was thinking of these speedway sliders, just not sure if they will work with a chrysler spring (stock springs right now, thinking of a mono later on)
http://www.speedwaymotors.com/Speedway-Heavy-Duty-Leaf-Spring-Sliders,5817.html
Re: Pics of leaf spring slider install [Re: mshred] #1191365
03/05/12 10:00 PM
03/05/12 10:00 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
no body has any pics they can post?? Come one guys...I did a search on this and all the pics are from the back and so far away that you need binoculars to see the sliders.
Re: Pics of leaf spring slider install [Re: mshred] #1191366
03/05/12 11:20 PM
03/05/12 11:20 PM
Topeka Kansas
K
ksj Offline
ksj  Offline
K
Topeka Kansas
Re: Pics of leaf spring slider install [Re: ksj] #1191367
03/05/12 11:35 PM
03/05/12 11:35 PM
A57_RT Offline
Parts Problem
A57_RT  Offline
Parts Problem
The afco ones say they are not meant to be used to change ride height, I took measurements from the oem shackle point and made my boxes and welded the slider units to them the placed the boxes on the frame in the proper spots and welded the boxes on...this was almost 4 years ago and I recently switched springs and all was like new in the slider dept.
Re: Pics of leaf spring slider install [Re: A57_RT ] #1191368
03/05/12 11:36 PM
03/05/12 11:36 PM
A57_RT Offline
Parts Problem
A57_RT  Offline
Parts Problem
Mounted..
Re: Pics of leaf spring slider install [Re: A57_RT ] #1191369
03/05/12 11:40 PM
03/05/12 11:40 PM
A57_RT Offline
Parts Problem
A57_RT  Offline
Parts Problem
install..
Re: Pics of leaf spring slider install [Re: A57_RT ] #1191370
03/05/12 11:41 PM
03/05/12 11:41 PM
A57_RT Offline
Parts Problem
A57_RT  Offline
Parts Problem
Done
Re: Pics of leaf spring slider install [Re: ksj] #1191371
03/05/12 11:45 PM
03/05/12 11:45 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
This help?
http://www.google.com/search?q=leaf+spri...mp;ved=0CCMQsAQ
nope, because I googled the exact same thing before I even made this post...notice how im asking this on a mopar forum, to see how guys with mopars did it...yup
gotta love the google geniuses
Re: Pics of leaf spring slider install [Re: A57_RT ] #1191372
03/05/12 11:46 PM
03/05/12 11:46 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
thanks for the pics! the install looks good!
I want to go to sliders, but if this is what has to be done, then it is more work involved than what im willing to get into right now
Re: Pics of leaf spring slider install [Re: mshred] #1191373
03/05/12 11:54 PM
03/05/12 11:54 PM
A57_RT Offline
Parts Problem
A57_RT  Offline
Parts Problem
I have seen many slap the slider unit right on the frame and weld it to lower the car, then there is the pinion angle to make sure its ok.
If thats in the stars, a new rear ect its not that hard, and actually my install was pretty easy in the big picture.
But do remember most your current setup is probably based off the way the cars sits now if the eyelet isnt close to the same position many things are gonna change.
Its one mod ive done that I never have to think twice about except check the slider bolt a few times each year to make sure its tight, always is.
Re: Pics of leaf spring slider install [Re: A57_RT ] #1191374
03/06/12 03:03 AM
03/06/12 03:03 AM
long island newyork
Abodyjohn88 Offline
Abodyjohn88  Offline
long island newyork
what is the benefit of using sliders?
Re: Pics of leaf spring slider install [Re: Abodyjohn88] #1191375
03/06/12 09:36 AM
03/06/12 09:36 AM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
Re: Pics of leaf spring slider install [Re: Mr340] #1191376
03/06/12 05:29 PM
03/06/12 05:29 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
there's another pic in this thread.
https://board.moparts.org/ubbthreads/show...;gonew=1#UNREAD
that pic helps...so essentially I can just weld the slider right under the frame rail then. I believe I have read that the rear spring eye needs to be 2/3rds of the way to the back of car at rest because upon acceleration it will move forwards right?
Re: Pics of leaf spring slider install [Re: Abodyjohn88] #1191377
03/06/12 05:35 PM
03/06/12 05:35 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
Less rise in the rear, therefore better weight transfer and less side to side movement.
Yeah, it's got a smallblock.
Re: Pics of leaf spring slider install [Re: 340B5] #1191378
03/06/12 05:43 PM
03/06/12 05:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
How is it less rise... if the two set ups have the
same spring and shock its the same rise... what it
does is reduce friction and eliminates side movement...
it shouldnt hit either end of the travel
Re: Pics of leaf spring slider install [Re: MR_P_BODY] #1191379
03/06/12 05:55 PM
03/06/12 05:55 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
No shackle moving through the 6:00 position.
Re: Pics of leaf spring slider install [Re: 340B5] #1191380
03/06/12 06:01 PM
03/06/12 06:01 PM
MR_P_BODY Offline
MR_P_BODY  Offline
the spring still does what it wants to but with less
friction
Re: Pics of leaf spring slider install [Re: MR_P_BODY] #1191381
03/06/12 06:17 PM
03/06/12 06:17 PM
off the grid
340B5 Offline
340B5  Offline
off the grid
Yup, can't control that unless a heavier spring is used.
