BB lifter strange
#1191246
03/04/12 08:53 PM
03/04/12 08:53 PM
Posts: 644 Warner Robins, Georgia
DusterMan
super street
super street
Pulled a cam out of my 383 to install a stock cam. Everything looked great except for this one lifter outside surface. Tha block is good and slick. I have never seen this in 40 yrs of messing with engines. What you think? these marks are all the way around and are evenly spaced like they were made in it. The lifter turned good in the block and the lobe surface and cam look great.
Pete: 2003 Dodge Quad 2500 Hemi 69 RoadRunner 4 sp Alpine White 2019 Dodge Charger
Re: BB lifter strange
[Re: Cab_Burge]
#1191248
03/04/12 09:27 PM
03/04/12 09:27 PM
DusterMan
super street
super street
No burr. Lifter bore are good. The marks on the top and bottom are perfectly lined up with each other. Almost like it was made that way. A burr would not be a perfect strait mark. ?? Got me.
[Re: DusterMan]
#1191252
03/05/12 01:08 AM
03/05/12 01:08 AM
Posts: 5,875 communist bloc of new jersey
jamesc
They are smooth as glass.
now they are
i can't see any way that pattern could be produced in the engine that had to be there when they were installed and may not have been readily noticeable
[Re: 440Jim]
#1191255
03/05/12 11:53 AM
03/05/12 11:53 AM
DusterMan
super street
super street
Well it fit the lifter bore fine. I checked it in a couple of others places and it fits the same. Mic the dia of the lifter and it measures the same as the good ones. Measured the lobe lift and it was the same as the other lobes .341. Weird!! I owned the car for 5 yrs and the one I got it from drove it everywhere. Nothing is hurt just weird looking.
[Re: dartman366]
#1191258
07/23/13 02:22 AM
07/23/13 02:22 AM
BeavisHQV
Hi,
did someone figured out what happened there? Have the same problem on only one lifter. Driverside, 3. cylinder exhaust valve.... exact similiar marks on the lifter as shown on his picture.
