How many quarts to refill 68 saginaw PS pump in B-Body #1190465
03/03/12 07:32 PM
03/03/12 07:32 PM
Northern NJ
68 Sat Offline OP
68 Sat  Offline OP
Northern NJ
As the title states. I need to refill my pump. Can't find in service manual.. Any help??
-Tx
1963 Chrysler 300 Pace Setter Convertible 21K mile survivor 1969 Dodge Coronet 500 1956 Desoto Hemi 1955 Chrysler C300
Re: How many quarts to refill 68 saginaw PS pump in B-Body [Re: 68 Sat] #1190466
03/03/12 07:50 PM
03/03/12 07:50 PM
NC
1970A66 Offline
1970A66  Offline
NC
Depends on what you emptied/replaced.
When I replaced a saginaw pump and gear box on a 70 Challenger and it took over large bottle of fluid (32 oz). Probably 38 oz.
I also disconnected the high pressure hose yesterday to replace the outlet valve assembly inside the pump. I needed about 16 oz of fluid because the pump drained.
Re: How many quarts to refill 68 saginaw PS pump in B-Body [Re: 1970A66] #1190467
03/03/12 10:44 PM
03/03/12 10:44 PM
Northern NJ
68 Sat Offline OP
68 Sat  Offline OP
Northern NJ
thanks I replaced the pressure hose as well....also did the mopar action pressure change...tx
