Rear Main Seal Diameter
#1190386
03/03/12 04:17 PM
03/03/12 04:17 PM
Posts: 1,288 Oregon
sg66mopar
Anybody know what the diameter of the seal surface on the crank is suppose to be on a big block. I'm fighting a rear main seal leak and am wondering if maybe the seal surface was turned too small at the factory. I can't make this thing run 20 minutes without spraying oil half way to China! Three different seals now in the last 4 days. I've pressurized the motor with about 1-1/2 PSI air and sprayed soapy water around the rear seal. It looked like a bubble bath. I could actually hear the air hissing out on one side where the two halves of the seal are suppose to mate up. Anyway, I measured the diameter of crank at the seal surface, best I could with the motor together and in the car. It appears to be 2.820" and I can't find the factory spec.
Re: Rear Main Seal Diameter
[Re: sg66mopar]
#1190392
03/03/12 09:06 PM
03/03/12 09:06 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
I just checked my AERA crankshaft manual and it lists it as 2.812 - 2.815 The World blocks had what was in my opinion a " fair" seal retainer and also some blocks had a problem with a machining process that must have been just wrong. Where the retainer slides in, there was a noticable ridge or step that was towards the bottom half of the side walls. Something is just not right, you shouldnt have that much trouble. Hope you get it figured out.
RIP Monte Smith
