1969 Road Runner Hoods #1190176
03/03/12 03:35 AM
03/03/12 03:35 AM
Ramona, CA
NicksGarage Offline OP
Ramona, CA
What's the difference between a 1969 Road Runner hood with and without the air grabber? I know there is a screened insert in the hood vents but is the underside of the hood the same? Someone asked me if this hood is an original air grabber hood. Sorry for the bad picture.
Re: 1969 Road Runner Hoods [Re: NicksGarage] #1190177
03/03/12 03:41 AM
03/03/12 03:41 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Hood is same, air grabber or not.
Re: 1969 Road Runner Hoods [Re: RobX4406] #1190178
03/03/12 12:33 PM
03/03/12 12:33 PM
Ramona, CA
Ramona, CA
Thanks, that's what I thought. I know there are reproduction air grabber boxes. Does someone make the screens that go into the air intakes?
Re: 1969 Road Runner Hoods [Re: NicksGarage] #1190179
03/03/12 12:41 PM
03/03/12 12:41 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
What's running up/down the center of that hood in the photo?
Hood itself is same AG or not from the cars I've had; holes were punched where AG attaches in all of them, AG or not.
Screen material is available commercially; I've thought about offering them.
Re: 1969 Road Runner Hoods [Re: NicksGarage] #1190180
03/04/12 02:34 AM
03/04/12 02:34 AM
indiana
marks69 Offline
marks69  Offline
indiana
Your picture is a 69 hood as the sheetmetal has been punched out to make the scoops functional. On 68 hoods the sheetmetal isn't punched out because the air grabber wasn't an option that year. All 69 underhood sheetmetal is the same so an air grabber could be added from the factory.
Re: 1969 Road Runner Hoods [Re: marks69] #1190181
03/04/12 11:30 AM
03/04/12 11:30 AM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
Mark69 is 100% correct. 68 hoods are not cut out for air grabber
Re: 1969 Road Runner Hoods [Re: NicksGarage] #1190182
07/02/12 11:07 AM
07/02/12 11:07 AM
Ramona, CA
Ramona, CA
Can anyone share some pictures of the air grabber box and how it is mounted?
Re: 1969 Road Runner Hoods [Re: NicksGarage] #1190183
07/02/12 11:23 AM
07/02/12 11:23 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I think all 69 hoods are the same
and the 68 hood has an early versus late hood. with the late 68 hoods the same as 69 hoods
Re: 1969 Road Runner Hoods [Re: NicksGarage] #1190184
07/03/12 12:04 AM
07/03/12 12:04 AM
N.E.Ohio
P
pacifica Offline
pacifica  Offline
P
N.E.Ohio
