Re: 440 motor home engine?
[Re: newportrider]
#1189836
03/02/12 09:38 PM
03/02/12 09:38 PM
Posts: 12,798 Benton, IL.
DaveRS23
Master of nothing...
Benton, IL.
All I ever use is the block and some tin from the trucks and motorhomes.
Master, again and still
[Re: newportrider]
#1189838
03/02/12 11:32 PM
03/02/12 11:32 PM
Posts: 43,714 Bend,OR USA
Cab_Burge
What has to be changed to use a 440 motor home engine in a car application?
It depends on what year motorhome, internal or external balanced, oil pan and pick up, motor mounts, maybe the exhaust manifolds and radaitor or swap your car water pump onto the motor home motor Maybe more If so, I can't remember what If internal balanced then the converter needs to be non external balanced, if external balanced then the converter balance needs to match the motor IHTHs
[Re: newportrider]
#1189840
03/03/12 09:30 AM
03/03/12 09:30 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
the motor home engins that I have seen are basicly just like anyother 440 like the first post says. The 413 Ind MH engines are the redheaded stepchild when it comes to converting to auto/car use.
I am truckless..
