LA Magnum cylinder heads #1189760
03/02/12 04:55 PM
03/02/12 04:55 PM
Colorado
DrDetroit Offline OP
Colorado
Did Mopar make a "Magnum" style cylinder head that will replace the standard LA 318/340 cylinder head as a direct replacement, without any modifications? Does anyone have the part number, and or casting number?
Re: LA Magnum cylinder heads [Re: DrDetroit] #1189761
03/02/12 05:23 PM
03/02/12 05:23 PM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
no, but enginequest does, it's the 318B part number, hughes sells them as their "iron ram" heads. they are a magnum head with LA intake bolt angle.
2017 Grand Cherokee Overland
Re: LA Magnum cylinder heads [Re: DrDetroit] #1189762
03/02/12 05:23 PM
03/02/12 05:23 PM
Andrewh Offline
Andrewh  Offline
I think the closest you are going to get is the new engine quest head.
they have a mag head with LA intake bolt pattern.
Re: LA Magnum cylinder heads [Re: Andrewh] #1189763
03/02/12 05:52 PM
03/02/12 05:52 PM
NY usa
540challenger Offline
NY usa
Don't you have to use magnum rocker gear. For does heads??? If so you will need new pushrods also. Correct me if iam wrong but the RHS head is a magnum style head that uses la intakes and la rocker shafts???
Re: LA Magnum cylinder heads [Re: 540challenger] #1189764
03/03/12 12:43 AM
03/03/12 12:43 AM
Indy LAX (RHS) is a magnum head that takes an LA intake, valve cover and rocker gear and is a direct bolt-on replacement on LA's. IIRC, they are no longer available from RHS, only from Indy and whoever sells Indy stuff.
