Greasy grimey parts! #1189734
03/02/12 04:34 PM
03/02/12 04:34 PM
California
moparbroz Offline OP
California
I have so many really good original parts for my project but they are caked with years of grease and grime. For example I have a trans cross member that is just caked with years of grimy greasy crud. I was thinking of soaking it in a bucket with a concoction of a good mixture of a cleaning agent. My question is what should I use? Simple green? What are your suggestions? Also have parts like my awesome 1969 BB torqueflite that obviously won't fit in a bucket. Spray with simple green and wipe? Suggestions from my Mopar brothers and sisters would be appreciated! Thanks much in advance!
Hebrews 11:1
Re: Greasy grimey parts! [Re: moparbroz] #1189735
03/02/12 04:56 PM
03/02/12 04:56 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
dollar store oven cleaner, lemon scented if you like. spray on let it soak for 10 minutes, scrub with a brush, hose off. wear rubber gloves/saftey glasses and do it outside.
Re: Greasy grimey parts! [Re: 65rbdodge] #1189736
03/02/12 05:02 PM
03/02/12 05:02 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Local carwash.
Re: Greasy grimey parts! [Re: moparbroz] #1189737
03/02/12 05:13 PM
03/02/12 05:13 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Invest in a pressure washer and a parts washer with mineral spirits. Both are needed if your gonna rebuild cars.
Gasoline also works great for cleaning parts and is cheapest.
Re: Greasy grimey parts! [Re: Challenger 1] #1189738
03/02/12 05:32 PM
03/02/12 05:32 PM
California
California
Very good! All excellent suggestions. I have taken parts to the car wash with great results. Issue there is it isn't as convenient as doing it at home (I know, what a whiner huh?). I have been lookin at pressure washers, parts washers, etc for years but have never pulled the trigger due to the dollars involved. I have never used gasoline to clean so....maybe I will give it a try. I hae used oven cleaner before and it worked ok. Thanks again!!
Hebrews 11:1
Re: Greasy grimey parts! [Re: moparbroz] #1189739
03/02/12 07:07 PM
03/02/12 07:07 PM
Central TX
roe Offline
roe  Offline
Central TX
When I did my engine bay it was horrible, just thick caked on crap. I sprayed it with oven cleaner then wire wheeled it. Then degreaser and wire wheeled it again. Then I scrubbed it all down with a really soapy mix using Ajax dish soap with bleach and stiff bristled brushes. Then sprayed with brake kleen right before painting. It worked awesome and was cheap. Took me a full day to really get my whole bay spotless, nooks and crannies included.
Roe
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Greasy grimey parts! [Re: roe] #1189740
03/04/12 01:21 AM
03/04/12 01:21 AM
Cut and Shoot, TX
kentj340 Online penguin-006
kentj340  Online Penguin-006
Cut and Shoot, TX
Parts that are really caked-up with grime should be scraped with a plastic knife or similar item that won't make scratches.
Soaps meant for dish washing machines usually contain amonia and are much stronger than soaps meant for hand dish washing. In fact, you should never use dish wash machine soap on good paint.
Strong dish washer machine soap, an old toothbrush, plus very hot water works very good. And it's free, and you don't have to take time off from playing with your car to go get some - just open the cabinet door under the sink, and there it is!
Just be sure to clean up the kitchen sink before wifey sees it.
Re: Greasy grimey parts! [Re: moparbroz] #1189741
03/04/12 07:47 AM
03/04/12 07:47 AM
places
79powerwagon Offline
places
Long-time nearly invisible member Alan LOVES his wife's dishwasher, as it does the best job!
His wife (on the other hand) isn't impressed...
Re: Greasy grimey parts! [Re: 79powerwagon] #1189742
03/04/12 09:38 AM
03/04/12 09:38 AM
nj
MoJoe Offline
MoJoe  Offline
nj
I just rebuilt my front end that was just caked with grease and dirt. I used Purple Power diluted 50% in a big tub. I soaked everything for a couple hours... scraped and scrubbed real good, then rinsed, then back in for a couple more hours... scrub/rinse, ect... Purple power removed the old paint and even looked like it started to eat away the rust. After a real good rinse and a hit with full strength PP on the stubborn stuff I put everything into the dishwasher... I put everthing that will fit in the dishwasher it works great and gets everything ready for whatever finish you want. I used Rustoleum rust converter and black Krylon semi gloss on my front end and although not correct everthing looks brand new.
Re: Greasy grimey parts! [Re: MoJoe] #1189743
03/04/12 09:59 AM
03/04/12 09:59 AM
western PA
mopar4ya Offline
mopar4ya  Offline
western PA
Load everything up and take it to your nearest machine shop. Have them run it through their cook tank. Might cost a few bucks, but it's fast and you don't have a mess to clean up at home. This will only work for disassembled parts, not the transmission.
Dan
Re: Greasy grimey parts! [Re: mopar4ya] #1189744
03/04/12 10:32 AM
03/04/12 10:32 AM
NY NY
3
340duster340 Offline
NY NY
I have done all of the above, but recently started using a steam blaster after easy stuff scraped off and degreaser applied directly to part
1966 Dart GT ...down to only 1 mopar for the first time in 15 years!
Re: Greasy grimey parts! [Re: kentj340] #1189745
03/04/12 10:41 AM
03/04/12 10:41 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
Soaps meant for dish washing machines usually contain amonia are much stronger than soaps meant for hand dish washing. In fact, you should never use dish wash machine soap on good paint.
this pretty much sums it up for the average guy at home,no easy fix just good ole fashon elbow grease.
Re: Greasy grimey parts! [Re: 340duster340] #1189746
03/04/12 10:42 AM
03/04/12 10:42 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
I would KILL for a quality (read: $$$) genuine steam pressure washer. Can't even rent one down here in Fumbuck County...
Re: Greasy grimey parts! [Re: Challenger 1] #1189747
03/04/12 10:59 AM
03/04/12 10:59 AM
IN
ahy Offline
ahy  Offline
IN
Good advice. They don't need to be expensive or fancy to help a lot. For many years I used a small inexpensive electric pressure washer... very helpful. A $70 parts washer from Harbor Freight works wonders. The 10 gallons of mineral spirit needed to fill it is a little expensive (don't use gasoline in this!).
For really nasty chassis parts with baked on grease and dirt, oven cleaner, ammonia or even paint stripper + pressure washer works well.
The way to use ammonia is to "gas it". Get a heavy trash bag, put the part(s) in it, add a pint or two of janitors strength ammonia, and seal. Let it work for a few hours or overnight, remove and pressure wash or scrub. Just don't do aluminum parts this way.
Re: Greasy grimey parts! [Re: ahy] #1189748
03/04/12 12:07 PM
03/04/12 12:07 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
small parts, for a quick degreasing, I'll use a coffee can, a splash of gasoline, and a brush.
Yes, gas is expensive,but it's cheaper than a gallon of paint thinner, mineral spirits, etc.
but purple power is also good stuff! I've taken a set of sludged abused heads that were sitting outside in a closed up engine for years, and the thing filled with water, mixed with the oil. it was like a milkshake inside. Soaked the heads in a 5 gallon bucket with purple power in it for a week. when I removed the heads, they looked like brand new fresh castings!! the paint, rust, grime, was gone
**Photobucket sucks**
Re: Greasy grimey parts! [Re: 70Cuda383] #1189749
03/04/12 12:09 PM
03/04/12 12:09 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Easy Off and the car wash.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Greasy grimey parts! [Re: moparmarks] #1189750
03/04/12 12:16 PM
03/04/12 12:16 PM
Ohio
LS-300 Offline
LS-300  Offline
Ohio
I a lot of times use the engine degreaser at the self wash. Advantage using the self wash is you can work until satisfied and they have a pit for the grease run-off as to not pollute too bad. It's also cheap!
1979 Chrysler 300 1968 Barracuda project
Re: Greasy grimey parts! [Re: LS-300] #1189751
03/04/12 12:40 PM
03/04/12 12:40 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
The worst part about degreasing parts at the car wash nowadays, is that you have to wear a ski mask and hoody like the unibomber to do it! All of the local car washes have signs that say "DO NOT WASH OUT TRUCK BEDS,OR CLEAN GREASY PARTS,ETC, " All of em have cameras, so look around before you make a mess you might have to pay to clean up.
Re: Greasy grimey parts! [Re: JDMopar] #1189752
03/04/12 12:58 PM
03/04/12 12:58 PM
California
California
All great suggestions. Thanks much!
Hebrews 11:1
Re: Greasy grimey parts! [Re: moparbroz] #1189753
03/04/12 01:05 PM
03/04/12 01:05 PM
California
California
Is this the purple power everyone is talking about?
http://www.clean-rite.com/
Hebrews 11:1
