.080 5/16 pushrod strenght #1189528
03/02/12 03:16 AM
03/02/12 03:16 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
my valve springs are set up at 590# open pressure. would an .080" wall thickness 5/16 pushrod be ok or do i need something heavier?
Re: .080 5/16 pushrod strenght [Re: mopar dave] #1189529
03/02/12 08:27 AM
03/02/12 08:27 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
How long will the pushrods be? Longer the pushrod the weaker it is.
You will probably be OK. A lot depends on how aggressive the cam and how hard you are going to turn it. It may not break but deflection is a power killer.
Leon
Re: .080 5/16 pushrod strenght [Re: Leon441] #1189530
03/02/12 08:49 AM
03/02/12 08:49 AM
tboomer Offline
tboomer  Offline
I would pm Todd at Competitionwedge. Give him your combos specs. For the Victor heads that will go on my RB 512,he speced Manton 3/8"x.095 pushrods.
Re: .080 5/16 pushrod strenght [Re: tboomer] #1189531
03/02/12 11:37 AM
03/02/12 11:37 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
I run Comp's Hi-Tech series in a 3/8 X.080 heat treated w/ 5/16 ball end's and have had good sucsess with them, if you have the clearance run the bigger size, as mentioned before deflection is a power killer.
Re: .080 5/16 pushrod strenght [Re: dartman366] #1189532
03/02/12 12:47 PM
03/02/12 12:47 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
if you going to get new ones, get the thick wall pushrods... Manton has the bets prices usually and they are the best you can get. You can get stage III .120 wall for about $200 shipped....
Heck Indy wants $180 for a set of there cheapo, cut to fit .080 walls, and your still going to make them.
I used Manton, for the 572 Hemi, and for the 560 CID wedge... both had Pacaloy springs, solid roller cams, with 800 lbs open pressure... I turned that wedge 8K a few times.
Re: .080 5/16 pushrod strenght [Re: Bob_Coomer] #1189533
03/02/12 12:53 PM
03/02/12 12:53 PM
IN
ahy Offline
ahy  Offline
IN
Think of the pushrod as a support column or beam... the extra diameter adds a lot of stiffness and strength. Its worth running 3/8" with a perfomrance spring even if you have to make room.
Re: .080 5/16 pushrod strenght [Re: mopar dave] #1189534
03/02/12 01:22 PM
03/02/12 01:22 PM
Shelbyville, TN USA
40ford Offline
mopar addict
40ford  Offline
mopar addict
Shelbyville, TN USA
You left out a lot of needed information. Are you oiling through the pushrod? Are you using a 48 or 59 degree block? Are you using offset roller lifters? What heads are you using?
Let me tell you why I ask these question. Years ago, We ran "x" blocks with 59 degree lifter bores/early Arrington heads----I had to use 3/8" pushrods. But, when we went to "R" blocks with W7(or 8 or 9)heads this allowed me to use offset roller lifters and get a short pushrod(7.25"). 5/16" was fine for this application. Even the "big time" oval track builders(Arrington, Petty, Fyrar) used 5/16" pushrods until the small blocks got to 10K+ RPM. Then, they went to 3/8" and even later 7/16". But these pushrods were lightweight and usually came from PPC in Arden NC. I think now they use Trend pushrods.
Re: .080 5/16 pushrod strenght [Re: 40ford] #1189535
03/02/12 02:25 PM
03/02/12 02:25 PM
Mt Morris Michigan
Mt Morris Michigan
i dont remember the lenght,but close to stock lenght. indy 360-1 and 1.6 t&d rockers. 59* block. cam lift is .700/.680 solid roller. non oil tru. 5/16 is the largest that will fit.
Re: .080 5/16 pushrod strenght [Re: mopar dave] #1189536
03/02/12 08:48 PM
03/02/12 08:48 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
i use a little bigger cam. 625# open. i use trend 3/8's x .135 wall. w9 heads. just had to notch head a little bit for clearence. seeya.
Re: .080 5/16 pushrod strenght [Re: rickraw] #1189537
03/02/12 09:30 PM
03/02/12 09:30 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
I used the Manton 3 series 5/16x.120 wall with springs that where over 700# over the nose with no problems spinning the motor to 8000 and these where recommended by Terry Manton.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: .080 5/16 pushrod strenght [Re: dusturbd340W5] #1189538
03/02/12 09:35 PM
03/02/12 09:35 PM
Mt Morris Michigan
Mt Morris Michigan
.120 wall i may be interested. It would take alot of grinding to fit a 3/8 pushrod.
Re: .080 5/16 pushrod strenght [Re: mopar dave] #1189539
03/02/12 11:01 PM
03/02/12 11:01 PM
tn
robnbird Offline
robnbird  Offline
tn
don't take chances 590 spring pressure is enough to bend a 5/16 .080 PR. Go with a 3/8 .080.
Re: .080 5/16 pushrod strenght [Re: robnbird] #1189540
03/02/12 11:48 PM
03/02/12 11:48 PM
Mt Morris Michigan
Mt Morris Michigan
Been running the 5/16 .080 wall pushrod for several years now, just thinking i may be losing some lift.
Re: .080 5/16 pushrod strenght [Re: robnbird] #1189541
03/03/12 12:21 PM
03/03/12 12:21 PM
Kissimmee Fl.
Kissimmee Fl.
I was running over 700# with a 5/16x.120 wall with 0 problems and was spinning it to 8000,and Terry Manton assured me I would be fine,but they where a little short at just under 7.00
