Re: Detonation problem
[Re: superb70]
#118911
09/10/08 10:08 PM
09/10/08 10:08 PM
RapidRobert
are you using a dial back light with that MSD.
[Re: superb70]
#118913
09/10/08 10:44 PM
09/10/08 10:44 PM
RapidRobert
A jumping around that severe could not come from the mechanical weight of the dist but would be from the electronics in the MSD or an issue such as a loose connection with the light.
[Re: bobby66]
#118915
09/11/08 11:50 AM
09/11/08 11:50 AM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
WHen was the engine rebuilt? Was the oil pump drive replaced? That causes things to bounce around too. detonation is another matter. What cam is in it? What heads?
