Synthetic brake fluid changeover #118877
09/10/08 09:32 PM
09/10/08 09:32 PM
Detroit area
6PAX Online content OP
6PAX  Online Content OP
Detroit area
My 70 Dart has factory small bolt pattern disk brakes. I am going to be switching it over to big bolt pattern disks up front and at the same time I am going to switch it over to manual from power. When I do this, I'd like to also switch over to synthetic brake fluid. Do I have to replace everything that has had the regular brake fluid in the past or can I somehow just flush out the system for the new synthetic fluid?
Re: Synthetic brake fluid changeover [Re: 6PAX] #118878
09/10/08 09:40 PM
09/10/08 09:40 PM
Stuart FL
mercman1 Offline
mercman1  Offline
Stuart FL
I switched over my GTX about 10 years ago. I was told to flush with the system with denatured??? alcohol that I got at Home Depot. No problems in 10 years.
Re: Synthetic brake fluid changeover [Re: 6PAX] #118879
09/11/08 08:40 AM
09/11/08 08:40 AM
Minn
SportF Offline
SportF  Offline
Minn
Really all you have to do is put the new stuff in and bleed all corners till the new stuff comes out. And since it is usually colored, you can tell by that. The stuff is made to mix with all types of brake fluid, thats the spec on it. Pour it in, pump away.
Re: Synthetic brake fluid changeover [Re: mercman1] #118880
09/11/08 08:42 AM
09/11/08 08:42 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
you don't have to flush anything when changing over to silicone brake fluid. just remove as much fluid from the master as you can and fill with silicone fluid. then bleed brakes until the silicone fluid flows out of the bleeders, silicone brake fluid is blue so you can easily see it flow out. i like to bleed one more time to remove any excess old fluid that may hide in the system.
don't worry about the 2 different types of fluid in your system. if there is any old fluid in your system it will not effect the silicone fluid. it may lower the boiling point and eat the paint off, but your brakes will work just fine.
remember silicone fluid retains air like the old stuff holds moisture. so if the bottle was shaken while on the shelf it could be full of air. if that happened and you don't remove the air your pedal will never get hard. one way to prevent this is to leave the silicone brake fluid out in the sun for a couple hours with the cap off to boil out the air trapped in the bottle or better yet place the bottle in boiling watter for 10 min.
perception is 90% of reality
