Front Shock Suggestion?? Street Strip car
#1188040
02/29/12 09:39 AM
02/29/12 09:39 AM
Posts: 4,243 Canada
Kam*Kuda
Canada
Would liek a suggestion for my Road Runner Street STrip car
Stock Front End, Torsion Bar Rear Ladder Bar Guessing 3500 lbs
Would it be pobbible to have a shock that is easily adjustable to stiffen for the street? I currently have comp 3 ways
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
Re: Front Shock Suggestion?? Street Strip car
[Re: Kam*Kuda]
#1188041
02/29/12 02:04 PM
02/29/12 02:04 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
I went 9's with the shocks you currently have, and found the adjustments actually do change how the shock works. Used them both on the street and the track for years.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: Kam*Kuda]
#1188043
02/29/12 06:10 PM
02/29/12 06:10 PM
Posts: 2,463 Sydney,Australia
tex013
Sydney,Australia
i use the QA1 single adjustables on my Satellite. full loose on the strip,midway on the street.easily adjustable with the wheel on,just reach around it
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
