Front Shock Suggestion?? Street Strip car
#1188040
02/29/12 09:39 AM
02/29/12 09:39 AM
Posts: 4,244 Canada
Kam*Kuda
Canada
Would liek a suggestion for my Road Runner Street STrip car
Stock Front End, Torsion Bar Rear Ladder Bar Guessing 3500 lbs
Would it be pobbible to have a shock that is easily adjustable to stiffen for the street? I currently have comp 3 ways
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
Re: Front Shock Suggestion?? Street Strip car
[Re: Kam*Kuda]
#1188041
02/29/12 02:04 PM
02/29/12 02:04 PM
Posts: 11,723 Portage,michigan
B3422W5
Portage,michigan
I went 9's with the shocks you currently have, and found the adjustments actually do change how the shock works. Used them both on the street and the track for years.
[Re: Kam*Kuda]
#1188043
02/29/12 06:10 PM
02/29/12 06:10 PM
Posts: 2,467 Sydney,Australia
tex013
Sydney,Australia
i use the QA1 single adjustables on my Satellite. full loose on the strip,midway on the street.easily adjustable with the wheel on,just reach around it
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
