1969 Dart Swinger stop lights not working #1187927
02/29/12 12:04 AM
02/29/12 12:04 AM
Minnesota USA
Dart6pak Offline OP
Dart6pak  Offline OP
Minnesota USA
I am working on a 69 Dart old race car.
Origional wiring was gone so I put in a replacement---taillights work--backup lights work---stop light switch tests out good --fuel wire pulses as it should but no brake lights.
The car does not have a directional signal switch or column harness--could that be the reason
Re: 1969 Dart Swinger stop lights not working [Re: Dart6pak] #1187928
02/29/12 12:08 AM
02/29/12 12:08 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Yep, that would do it! The turn signals and the stop lights are the same filament...
JB Rhinehart, Realist
A-Body's RULE!
Re: 1969 Dart Swinger stop lights not working [Re: Rhinodart] #1187929
02/29/12 12:16 AM
02/29/12 12:16 AM
What Rhino said, The white "out" wire from the brake light sw goes into the TS sw then 2 wires out from the TS sw to the brake light on each rear corner, the large filament in the 1157 bulbs
Re: 1969 Dart Swinger stop lights not working [Re: RapidRobert] #1187930
02/29/12 12:25 AM
02/29/12 12:25 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If you aren't going to have turn signals on the car then you can run a wire from the brake light switch to the rear bulbs.
