Need help 67 dart #1187810
02/28/12 11:01 PM
02/28/12 11:01 PM
United States
fadeaway5 Offline OP
United States
I have a 318 with a 727 and need the kick down linkage from the carb all the way back with brackets etc. can anyone point me in the right direction to get one.thanks
Re: Need help 67 dart [Re: fadeaway5] #1187811
02/28/12 11:59 PM
02/28/12 11:59 PM
Round Lake Beach, Illinoisy
Rhinodart Online penguin-006
Rhinotruck
Rhinodart  Online Penguin-006
Rhinotruck
You need to find the kickdown from any 340 A-Body. I had a factory 318 727 68 Dart convertible because it was a tow package car. There should be a few vendors that have it. EDIT: found several sites that have it $419! Didn't know it got that expensive! May check the A-Body for sale ads here.
JB Rhinehart, Realist
A-Body's RULE!
Re: Need help 67 dart [Re: Rhinodart] #1187812
02/29/12 12:47 AM
02/29/12 12:47 AM
Pataskala, Ohio
GTX70sixpack Offline
Pataskala, Ohio
You can use later model cable style, the 70's style normaly has clearance problems with the firewall on early models
65 Belvedere II Station Wagon
69 Coronet R/T convertible
70 GTX
70'cuda
99 Dodge Diesel dually 4X4
Re: Need help 67 dart [Re: GTX70sixpack] #1187813
02/29/12 01:52 AM
02/29/12 01:52 AM
United States
United States
Thanks guys I'm looking into it now
Re: Need help 67 dart [Re: fadeaway5] #1187814
02/29/12 04:18 AM
02/29/12 04:18 AM
waco tx
gogo318 Offline
gogo318  Offline
waco tx
it may not be year ,model correct but the early 80s diplomat/5th avenues use a double pivot linkage system that i really like you could dig up at a bone yard there all 318/727-904 cars im sure it would fit your setup
67 charger fastback 318 stock 67 belvedere II 4dr soft top built 318 68 newport 2dr hard top 318 84 b150 440/727 84 d150 short wheel step side 4x4 lifted 87 omnitruck (you just have to see it ) new addition 63 dart wagon !!!
