Re: GROOVED #5 MAIN BEARING????
[Re: Labratt]
#1187698
02/29/12 02:45 PM
02/29/12 02:45 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
Not needed if the seal and retainer are properly installed, with a good quality seal.
RIP Monte Smith
[Re: Moparnut426]
#1187702
02/29/12 05:42 PM
02/29/12 05:42 PM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
I really need to find the time to sit down and write out a "How To" on Mopar rear main seals. Maybe title it "Myths, Legends and Old Wives Tales" #1 YES you can use a "rubber" rear main seal on a "O.E.M." crankshaft that has a knurl. Chinese "Aftermarket" cranks have been known to need attention. #2 Shaft seals are designed to ride on a film of oil. Just like a bearing they don't last long at all without lubrication. #3 Those that "feel the need" to use Silicone/RTV on their rear main seals. 1) have no confidence in the seals they are using from the get go. 2) have dodged a bullet for years, so it must help. 3) believe everything they read. I'm sure there's more but don't have the time to go on right now. Let the silicone users flaming begin Randy, Yes Todd does use and offer my rear seals. He stocks the Fluoroelastomer aka Viton (Viton is a trade name of DuPont)
