Re: CSR transmission sheild fitment??
[Re: hemi-itis]
#1187606
02/28/12 04:47 PM
02/28/12 04:47 PM
BradH
I did the seam on my BB E-body for some additional vertical clearance, but the install was straight foward. At some point CSR switched from Allen-head to 6-point-head bolts which allow (at least on my car) for reaching over the top of the engine to reach them, rather than having to drill through the floor / firewall like some people said they used to do for bolt access.
[Re: rickraw]
#1187608
02/28/12 09:21 PM
02/28/12 09:21 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Try bolting it onto the engine. I spent HOURS trying to get all the bell bolts in only to find that one of the holes in the shield was dilled in the wrong spot. I'm not the only one to have that problem. They also charged me to ship the thing back to them for "repairs". In my opinion, It was made wrong and should have been replaced.
[Re: TRENDZ]
#1187609
02/28/12 11:56 PM
02/28/12 11:56 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
same here.
[Re: rickraw]
#1187612
02/29/12 10:15 AM
02/29/12 10:15 AM
Posts: 4,243 Canada
Kam*Kuda
Canada
Well hopefully they fit the car too.
I removed the pinch.Welded for some extra strength
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
[Re: hemi-itis]
#1187613
02/29/12 10:29 AM
02/29/12 10:29 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
Seems you all have A or E bodies.Anybody with a b body??
68 RR,beat the pinch weld in the tunnel as flat as you can get it.ive heard of some who say they didnt have to do it but i cant see how.i had to do it on my 68 and 69 b-body.
[Re: hemi-itis]
#1187614
02/29/12 03:04 PM
02/29/12 03:04 PM
Posts: 1,377 Ohio
Todd
Ohio
Yes, fits good. The only thing had to do was clearance the floor on the right side for the buckle on the strap.. No modification to the pinch weld needed.
[Re: hemi-itis]
#1187616
02/29/12 04:56 PM
02/29/12 04:56 PM
Posts: 46 Finland
LUMI
Finland
been fitting one to my -68 Charger needs a lot of hammer maybe next week or i get a Stroud blanket next
[Re: fishy340]
#1187620
02/29/12 10:40 PM
02/29/12 10:40 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
Thanks fellas,Seems the older "B" bodies have more room than the newer ones.I'm picking up the new Pro Torque converter tomorrow so it's time to get crakin!!
