anyone use the 1/2" 4500 to 4150 adapter
#1187517
02/28/12 11:50 AM
02/28/12 11:50 AM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I recently purchased a mr. gaskets #1930 carb adapter and just cant get the dogleg bolts to line up with my carb bolt holes. Here is the adapter http://www.jegs.com/i/Mr.+Gasket/720/1930/10002/-1 Is there some kind of trick to this setup?
67' charger 499 RB
10.57 at 127
Re: anyone use the 1/2" 4500 to 4150 adapter
[Re: FlyFish]
#1187522
02/28/12 01:24 PM
02/28/12 01:24 PM
dragram440
bigfork mn
I already have ab 16" x 2" drop base air cleaner with a 3 1/2" tall k&n with a xstreme flow filtertop. The problem is the 2" drop base with a 3 1/2" filter doesnt allow much flow between the lid and the drop base and the lid is at most 1/4" or closer to the bottom of the scoop so I dont think the filtertop will be doing anything.
67' charger 499 RB
10.57 at 127
[Re: dragram440]
#1187523
02/28/12 01:45 PM
02/28/12 01:45 PM
dragram440
bigfork mn
I would be interested to hear if someone else had made one of these work.
67' charger 499 RB
10.57 at 127
[Re: 340_Dart]
#1187528
03/02/12 02:33 PM
03/02/12 02:33 PM
dragram440
bigfork mn
I got the carb bolted on with a little tweaking. Now we will see if it hinders the performance. Lots of clearance for my air cleaner now.
67' charger 499 RB
10.57 at 127
