440 question #118733
09/10/08 03:40 PM
09/10/08 03:40 PM
Manteno, IL
dakota27 Offline OP
dakota27  Offline OP
Manteno, IL
i have a stock 440 block standard bore and stroke. will a .590 purpleshaft cam open the valves too far and hit the piston? or do i need pistons with eyebrows?
Re: 440 question [Re: dakota27] #118734
09/10/08 05:42 PM
09/10/08 05:42 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
You will need pistons withs some compression to make that cam work good and yes I feel that you will need reliefs.
Re: 440 question [Re: dakota27] #118735
09/11/08 12:24 AM
09/11/08 12:24 AM
SoCal
Brian Hafliger Offline
SoCal
Yes you'll need valve reliefs for that cam. KB has some good inexpensive pistons...
What are you trying to do with this engine?
Brian
Brian Hafliger
Re: 440 question [Re: Brian Hafliger] #118736
09/11/08 12:37 AM
09/11/08 12:37 AM
It would depend on how far in the hole you are & with stock pistons if you are far enough down to be safe as mentioned you wont have enough CR to make it work.
Re: 440 question [Re: RapidRobert] #118737
09/11/08 09:12 AM
09/11/08 09:12 AM
dogdays Offline
dogdays  Offline
RR got it right. If the pistons are down far enough that you don't have valve interference, the compression ratio is so low that the cam won't work.
BUT, the cam is too big because the 440 stock pistons and rods aren't made for high rpm where the cam starts making power.
So what do you really intend to do with the car and what car is it?
R.
Re: 440 question [Re: dakota27] #118738
09/11/08 09:16 AM
09/11/08 09:16 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
big cam for general applications. Like they said, depends on compression. A 71-up block might work but then how much compression are you gonna have?
