i have a stock 440 block standard bore and stroke. will a .590 purpleshaft cam open the valves too far and hit the piston? or do i need pistons with eyebrows?
big cam for general applications. Like they said, depends on compression. A 71-up block might work but then how much compression are you gonna have?
